The problem with the function of the vector
The problem with the function of the vector - 消息
#1 已发布: 2020/4/7 11:49:26
Andrey007
Andrey007
0个赞,共7个帖子。
Please help with the prZadanie 2.sm (9.86 KiB)已下载 1470 次。oblem. For some reason, the program does not like the range j, why it is not clear.
Thanks for the help
#2 已发布: 2020/4/7 16:16:24
Andrey007
Andrey007
0个赞,共7个帖子。
未找到文件。
Please help with the pr未找到文件。oblem. For some reason, the program does not like the range j, why it is not clear.
Thanks for the help
#3 已发布: 2020/4/7 16:19:22
Andrey007
Andrey007
0个赞,共7个帖子。
#4 已发布: 2020/4/7 19:47:33
1,443个赞,共2,936个帖子。
Hello [userlink]Andrey007[/userlink]
Here there is your code adaped to SS syntax.
To loop the (scalar) functions through the values of a vector (1-column matrix) you can use vectorize or a for/while function.
Since in A=0 Kg(A) is indeterminate (0/0) and Kn(a) is an infinity and you can't plot that I've started the range from the 2nd value within the original range.
Zadanie 2_1.sm (12.66 KiB)已下载 1462 次。
#5 已发布: 2020/4/8 09:29:23
983个赞,共6,866个帖子。
Sorry for some gross mistake ... deleted.
You can use Smath code floor/ceiling
Zadanie 2_1[floor].sm (15.05 KiB)已下载 1280 次。
#6 已发布: 2020/4/8 17:48:42
Andrey007
Andrey007
0个赞,共7个帖子。
Thanks for the help, be healthy!
