Text without "" quotation marks ?
Text without "" quotation marks ? - Messages
#1 Posted: 2024/3/25 16:19:07
Alex Costila
Alex Costila
1 likes in 13 posts.
Is it possible to display the text from a definition without the quotation marks and colored text?
I can fix colored text by printing B&W , but quotation marks are annoying.
#2 Posted: 2024/3/26 00:32:23
⚜ Kenny Lemens, P.E. ᵂᴵ
85 likes in 179 posts.
Greetings,
By its very nature, a string needs quotations to indicate that it is a string.
As for the Color, you can adjust your settings in the Program Files Folder on your C-drive to change the color of a string object, but the quick way would be to select your math statements, and change the color of the text to an off-black in the formatting toolbar (black = reset defaults, but an a shade off of black will change the color of the text as desired).
May this be of Good Help;
#3 Posted: 2024/3/26 00:55:07
Alex Costila
Alex Costila
Greetings,
Thank you, but i was looking for a way to make the text from string blend with normal text . Quoatation marks are a bit annoying...
