vectorise() go to deep without first calculating the matrix product
vectorise() go to deep without first calculating the matrix product - I think it should multiply the matrices first and then apply the comparison per line. - 消息
#1 已发布: 2019/8/16 12:18:08
manti7
manti7
0个赞,共2个帖子。
I think the vectorize() command goes too deep in the example. Probably it takes the first row from the first matrix, then it probably tries to multiply it with the second vector. Then I get the error message: Number of rows and/or columns of matrices or vectors do not match.
Can somebody take a look at this, please?
matrix_nested_function.sm (11.57 KiB)已下载 1191 次。
#2 已发布: 2019/8/16 14:05:19
CBG
CBG
78个赞,共312个帖子。
Maybe this is a simple way to solve the problem
matrix_nested_function_CBG.sm (11.45 KiB)已下载 1172 次。
#3 已发布: 2019/8/16 14:07:39
Arie
Arie
94个赞,共285个帖子。
Can eval input to f() as such
matrix_nested_function_alyles.sm (12 KiB)已下载 1220 次。
#4 已发布: 2019/8/16 14:50:18
manti7
manti7
0个赞,共2个帖子。
Thank you both for the quick answer! I didn't know there was an eval() function. I now understand that SMath resolves everything as low as possible and then calculates in one go. The use of eval() in the right place prevents this.
#5 已发布: 2019/8/16 16:51:54
983个赞,共6,866个帖子。
Maybe you complicate matters or not make it simpler from the truth table.
#6 已发布: 2019/8/16 16:55:56
983个赞,共6,866个帖子。
... some stuff Truth table
Utilities Matrix Truth Table [Locate row_col].sm (43.39 KiB)已下载 1053 次。
