I pedaled on that one, not to avail. Maybe there is no way ?
Toke just little bit from NotePad ... it returns full expansion
instead of the two cols only numerical values.
Mathcad WRITEPRN does it fine ...
Smath missing WRITEPRNAs you open the work sheet, it should create the file system.
Thanks "All Doctors" if you can reconciliate this patient.
Random Chirp Outliers.sm (119.38 KiB)已下载 1303 次。
