trace() function broken
trace() function broken - 消息
#1 已发布: 2012/7/3 03:22:52
1,362个赞,共2,276个帖子。
I get the following with build 4559
[MATH lang=eng]trace(mat(1,3,2,4,2,2))=1@#[/MATH]
I need the trace function to fake the also broken norme() function using
[MATH lang=eng]M:mat(1,2,3,4,2,2)@#[/MATH]
[MATH]norm_e(M):sqrt(trace(transpose(M)*M))[/MATH]
Best regards, Martin Kraska
#2 已发布: 2012/7/3 04:18:12
kmihaylovich
kmihaylovich
8个赞,共131个帖子。
Hmm, what results do you expect?
#3 已发布: 2012/7/3 05:00:09
325个赞和1个踩,共2,052个帖子。
BTW., trace() is reserved function for debugging purpose - trace evaluations through Output window - see trace()
#4 已发布: 2012/7/3 13:58:26
1,362个赞,共2,276个帖子。
ok, that is just my fault, I expected trace to be the trace of a matrix, i.e. the sum of the diagonal elements. In fact, I have to use tr(), than everything works as expected:
[MATH lang=eng]M=mat(1,2,3,4,2,2)@#[/MATH]
[MATH lang=eng]sqrt(tr(transpose(M)*M))=sqrt(30)@#[/MATH]
Thanks for the hints!
