Units problem
Units problem - SI units default - 消息
#1 已发布: 2019/3/20 11:35:31
The Cross
The Cross
0个赞,共73个帖子。
When I use Smath, the SI units are default, even if I define all my units and variables in IP (US standard) units, the automatic calculation comes back in metric. Is there a way to change this setting?
#2 已发布: 2019/3/20 11:48:08
Arie
Arie
94个赞,共285个帖子。
Not by default. You must manually change the unit in the evaluation.
Andrey Ivashov 2019/3/20 13:57:00
