Rounding to multiple of
Rounding to multiple of - Nearest ones, tens, hundreds, etc. - 消息
#1 已发布: 2016/4/28 15:24:48
Ruben Sidranski
Ruben Sidranski
17个赞,共465个帖子。
I would like to have the answer "round" to the nearest XXX. In this example, I would like an answer that gives 520 and another that gives 500
I do not want to truncate to get the 500 as I may get 589 and would like to round up
Apparently, units are part of the problem
#2 已发布: 2016/4/28 15:38:05
1,443个赞,共2,936个帖子。
Something like this?
2位用户喜欢此帖子
ElSid 2016/4/28 15:48:00, frapuano 2016/4/28 17:24:00
#3 已发布: 2016/4/29 00:43:01
Ruben Sidranski
Ruben Sidranski
17个赞,共465个帖子。
New built-in function, Round? Notice the capital "R"
Thanks for the work around
#4 已发布: 2016/4/29 02:26:38
Mike Kaganski
Mike Kaganski
184个赞,共434个帖子。
Actually, I understand everyone who faces some problem, creates a function that helps him to solve it, and immidiately suggests to make it "built-in".
Yet, I want to note that it could be undesirable to clutter the main program with loads of utility functions. This way, growing weight is put on developer to support these functions.
It's better to include them to extensions (yet, this way the extension maintainer gets responsible for it).
But the best of it is the very ability of SMath to create custom functions like that Davide's one, that may be easily put into any sheet. If one prooves to be useful enough, Snippets is a very good place to put it.
С уважением, Михаил Каганский
Davide Carpi 2016/4/29 04:10:00
#5 已发布: 2016/4/29 04:12:38
1,443个赞,共2,936个帖子。
Seems to me a bad choice; when I provide functions made with this approach (case different on first character) the twin function can do the same things of the original when used with the same number of arguments (here is not possible). mround is not casual, it's the excel name for this function (round arg1 to the nearest multiple of arg2)
#6 已发布: 2016/4/29 08:33:18
Ruben Sidranski
Ruben Sidranski
17个赞,共465个帖子。
I understand the "built in" function request conundrum. This is now in my user defined collapsed area. Doing HVAC, precision is not imperative and I round ... alot. In MathCAD, the function was Round, which is why I suggested capital R.
You guys are awesome!
#7 已发布: 2016/4/29 10:38:30
983个赞,共6,866个帖子。
Can't be more right Mike !
Martin mentionned that some time ago. How much did I ask ? Almost nothing except for the
vectorising operator @ my begining of Smath. Conveniences like the square matrix bracket, ranging operators in the palette... So many plugins past version 5346 ??? More maths: yes in the sense of how to make Smath do more, like your Vicenty geographical distance.
Cheers Mike, Jean.
#8 已发布: 2016/4/29 10:41:13
983个赞,共6,866个帖子。
