Is it possible Interrupt Processing and reactivate it when required ?
Is it possible Interrupt Processing and reactivate it when required ? - 消息
#1 已发布: 2024/10/6 21:52:02
francesco rapuano
francesco rapuano
15个赞,共38个帖子。
Probably my one is a stupid question but I find that is a little bit frustrating that having to do several changes in a long and time consuming program after each editing step the program restart and it is necessary to interrupt it processing using the Interrupt Icon; obviously for 10 changes you need to do this step 10 times even when you move an area slightly.
What make me wonder is if does exist a way to stop the program running till have been applied several changes and then restart it again at the end of this process or however when the user requires this.
Thanks in advance for any feedback and best regards
Franco
#2 已发布: 2024/10/7 05:05:40
1,443个赞,共2,936个帖子。
In the Calculation section of the main menu, disable auto calculation.
#3 已发布: 2024/10/7 19:52:57
francesco rapuano
francesco rapuano
15个赞,共38个帖子。
Thanks a lot Davide for your answer ; I was really not aware of this feature ( and of many others) .
Franco
