[Data Exchange Plugin] Export data (more than 4 columns)
[Data Exchange Plugin] Export data (more than 4 columns) - Problem exporting to CSV file - 消息
#1 已发布: 2017/3/29 06:08:24
chandragon
chandragon
0个赞,共3个帖子。
Hi everyone !
I'm new to SMath Studio and find it really great, thanks a lot for this awesome tool !
But I came across a problem I don't find how to solve:
I want to export my data (a big matrix) to a csv file that would be arranged like this:
0.01,201060,237680,198853.285077439
0.015849,143256,185072,174269.293182435
0.025119,93978,149668,133006.974667634
0.03981,57338,110334,83471.8795836333
0.063095,35432,79992,43221.3253258427
0.1,20672,57000,19652.9918548953
0.15849,11280.4,40188,8399.57161545733
0.25119,6361.6,27224,3544.56326448012
For that, I use a matrix to which I add the colums one by one and use the CVS/ODT plugin:
M:=augment(col1;col2)
M:=augment(M;col3)
M:=augment(M;col4)
export_CSV(M,"filename")
And that works fine up to 4 columns... but for a reason I don't understand if I add more columns it ends up writing the file as:
"mat(0.01,201060,237680,198853.285077439,0.015849,143256,185072,174269.293182435,0.025119,93978,149668,133006.974667634......
Can you help me get the same file format with more columns ?
Thanks !
#2 已发布: 2017/3/29 07:48:02
1,443个赞,共2,936个帖子。
Hello [userlink]chandragon[/userlink]
could you provide a file with an example that doesn't work for you, I'm not able to reproduce your issue
#3 已发布: 2017/3/29 12:58:37
983个赞,共6,866个帖子。
For that, I use a matrix to which I add the columns one by one
Give some hint about your matrix:
1. created in Smath as an 2D image ?
2. columns from foreign source or from Smath modules ?
If foreign from source as individual columns
easy to augment via a little piece of program.
#4 已发布: 2017/3/31 06:43:35
chandragon
chandragon
0个赞,共3个帖子。
Hi and thanks for your answers.
Giving you the .sm file would be complicated because of the plenty of files it opens...
But here is the output file I get:
mydata.7z (4.22 KiB)已下载 665 次。
If I remove the " " and try to read it with rfile it gives the value 0.
The matrix I write is pretty big but here is what it looks like when I want to show it:
The number of lines matches.
It is created via a succession of augment() of columns made of real and imaginary parts of complex arrays that are created line by line in a for loop, example for one of them here:
#5 已发布: 2017/3/31 07:53:00
chandragon
chandragon
0个赞,共3个帖子。
Problem solved using only one augment() call to create the matrix like Davide Carpi did!
Thanks again !
#6 已发布: 2017/3/31 18:57:12
983个赞,共6,866个帖子。
Your collection is not a matrix; it is an MDA [Multi Dimensional Array => Matlab]
or a CELL ARRAY [Mathematica]. No matter, the "collection" can be spooled to file
and recalled from file, just do it the right way as exemplified [attached].
File Create.sm (24.67 KiB)已下载 1292 次。
... you can't remove the quotes "..."
