eval bug with 3d plots
eval bug with 3d plots - 消息
#1 已发布: 2012/8/10 10:35:59
nadir
nadir
0个赞,共4个帖子。
I've found the following bug:
if a function z(x,y) is used inside an eval command the mesh of the function is incomplete.
Try with: eval(z(x,y)) where z(x,y)=x^2+y^2
See attached file.
N
#2 已发布: 2012/8/10 15:23:40
325个赞和1个踩,共2,052个帖子。
(I have an image to explain what I wonat to say, but I do not know how to insert a figure below).
See this attached pictures please. You can attach-upload one of more pictures or files after posting (upper picture), or before posting (lower picture).
#3 已发布: 2012/8/10 16:31:47
nadir
nadir
0个赞,共4个帖子。
Thank you for your suggestion.
Now a picture is attached to my post
N
