Do I have to use Insert > Function in order to use solve
Do I have to use Insert > Function in order to use solve - 消息
#1 已发布: 2022/9/23 07:54:39
mateo
mateo
0个赞,共2个帖子。
I can use Solve using the command Insert > Function. But if I write the same directly without the Menu, it won't work. What could be the reason?
#2 已发布: 2022/9/23 08:20:34
127个赞,共342个帖子。
You should check the use of capital or tiny "s". Also only if you have installed the "Maxima" plugin you have both "solve" and "Solve" that have a different solutor and also a different form
#3 已发布: 2022/9/23 09:28:54
mateo
mateo
0个赞,共2个帖子。
Thank you. I wrote solve indeed with tiny s and I don't have the Maxima plugin. However, I tried it once again today and it worked.
#4 已发布: 2022/9/23 13:38:41
983个赞,共6,866个帖子。
