Corrupted File - SMath Crash after Opening
Corrupted File - SMath Crash after Opening - SMath Crashes Upon Opening File - 消息
#1 已发布: 2018/4/16 17:51:40
Ryan Freund
Ryan Freund
20个赞,共339个帖子。
Are you able to open the attached file? SMath seems to crash when I open the file.
Thanks!
East Balcony Design.sm (170.94 KiB)已下载 1308 次。
#2 已发布: 2018/4/16 18:19:05
1,362个赞,共2,276个帖子。
The last region makes SMath crash regardless of the auto-calculate state.
Remove it and the file can be read.
  <region id="96" left="18" top="3051" width="77" height="32" color="#000000" bgColor="#ffffff" fontSize="8">
    <math>
      <input>
        <e type="operand">V.u_flr</e>
        <e type="operand">a</e>
        <e type="function" args="3">at</e>
        <e type="operator" args="2">:</e>
      </input>
    </math>
  </region>
East%20Balcony%20Design-1-95.sm (170.61 KiB)已下载 1364 次。
Davide Carpi 2018/4/17 02:53:00
#3 已发布: 2018/4/16 18:46:24
Ryan Freund
Ryan Freund
20个赞,共339个帖子。
How do I open the SMath file as you show? Do I simply open it in a text editor?
Thanks!
#4 已发布: 2018/4/17 02:55:10
1,443个赞,共2,936个帖子。
Seems there was an issue in math serialization, at lesat 2 arguments missing
Do you remember if the file ended in this way or there were more things?
Thanks!
Yes
