Stable: SMath Studio 0.92 (25 February 2012)
Stable: SMath Studio 0.92 (25 February 2012) - 消息
#1 已发布: 2012/2/25 13:45:42
2,344个赞,共4,057个帖子。
组: Super Administrator
New SMath Studio 0.92 Stable available
Last changes
  • Printing bounds displaying implemented directly on the worksheet;
  • Printing improved: added ability to specify pages to print, print current page only (the page where cursor is located) or to print a selection;
  • Context Menu items now also added to Edit button of the Main Menu;
  • Graph animations performance improved up to 20%;
  • Calculations performance improved;
  • Program will now cancel any try to copy selected regions to the same location as initial using Ctrl key;
  • Current Region (Region with cursor inside) is now always shown on top (z-index) of others;
  • Hiding of the error when removing a region fixed;
  • Improved showing of the current error status of the Region;
  • Print preview dialog improved;
  • Plot Region error handling improved;
  • Added internal support for color and alignment of the Header and Footer text on print out;
  • Fixed critical error appeared when pressing on the Graph related buttons from Plot Math Panel if no Plot Region focused;
  • Fixed math panels issues appeared when screen DPI not equal to 96;
  • Fixed infinite loop issue appears for complex functions when math error occurs inside;
  • Fixed blinking of the Separator Region on worksheet horizontal scroll;
  • Several issues fixed appeared when non-standard Worksheet's scaling used;
  • Fixed drawing issue appeared on Grid displaying property changed when two or more Worksheets are shown side by side within one instance of the program;
  • Fixed error of the Symbolic Library appears when working with Units for expressions with numeric optimization;
  • Changing of the latin symbol to greek one or vice versa using Ctrl+G repaired for Text Region;
  • Fixed error appears on printing of the large Regions;
  • Fixed critical error on program startup when any of snippets has no Title set by File > Properties;
  • Couple of issues fixed regarding copying of content close to the collapsed Area Region;
  • Fixed error popup animation issue (animated twice);
  • Fixed issue appeared some times on pasting content from clipboard: region was not visible till any other user's action;
  • Language files updated;
  • Refactoring.
System requirements
  • Desktop (Windows):
    Framework: .NET Framework 2.0
  • Desktop (Linux):
Interface languages
Desktop и Handheld (34 languages):
  • [BUL] Bulgarian / Български
  • [CAT] Catalan / Català
  • [CZE] Czech / Čeština
  • [DAN] Danish / Dansk
  • [DUT] Dutch / Nederlands
  • [ENG] English / English
  • [FAS] Persian / فارسی
  • [FIN] Finnish / Suomi
  • [FRE] French / Français
  • [GER] German / Deutsch
  • [GRE] Greek / Ελληνικά
  • [HEB] Hebrew / עברית
  • [HUN] Hungarian / Magyar
  • [ITA] Italian / Italiano
  • [LAV] Latvian / Latviešu
  • [LTH] Lithuanian / Lietuvių
  • [NOR] Norwegian / Norsk
  • [POL] Polish / Polski
  • [RON] Romanian / Română
  • [RUS] Russian / Русский
  • [SCR] Croatian / Hrvatski
  • [SLK] Slovak / Slovenčina
  • [SPA] Spanish / Español
  • [SWE] Swedish / Svenska
  • [TUR] Turkish / Türkçe
  • [UKR] Ukrain / Українська
    Free Download
    Note: No SMath Studio Handheld 0.92 release will be introduced. Please use the latest stable handheld version (0.90).
    Tutorial
    Other files
  • 3位用户喜欢此帖子
    Radovan Omorjan 2012/2/25 16:00:00, IVR 2012/2/25 18:53:00, Oscar Campo 2012/2/27 12:09:00
