1页(4条)
Hidden inputs are being printed - Hidden inputs are being printed to pdf file - 消息
I'm trying to print some calculations to PDF in a pseudo-table format by hiding the inputs. However when I try to print to PDF, the inputs are displayed and ruin the table.
The screenshots below are how it appears in SMath vs how it appears in the resulting PDF.
It only seems to be the case when a variable is defined; if the input is just a calculation then it will remain hidden.
Is there a way to prevent it from displaying the calculation input?
Thanks
Thanks
已编辑 2026/11/6 18:48:29
WrotePlease attach .sm file
I've attached a file that shows the table in question, with some equations simplified to reduce the extraneous details.
When I plot this to pdf, it appears as shown in the screenshot above. Interestingly, if I copy this 'table' to a new file and plot it, the problem goes away. I have no idea what setting/parameter would cause that to happen though.
temp.sm (11.76 KiB)已下载 113 次。
已编辑 2026/11/9 14:48:52
1页(4条)
