Clearing Variables for Re-use in same document
Clearing Variables for Re-use in same document - 消息
#1 已发布: 2025/3/19 05:07:38
DM
DM
0个赞,共12个帖子。
I'm using SMATH to bring in template calcualtions and substitute for hand calculations, but one thing I couldn't figure out is if it is possible to "clear" a variable so I can use the equation multiple times without carrying variables forward. I tried using the separator, but it doesn't clear variables.
#2 已发布: 2025/3/19 06:12:39
⚜ Kenny Lemens, P.E. ᵂᴵ
85个赞,共181个帖子。
Greetings,
In the 「Special Functions」 Plugin, you can get access to the function "Clear()". Here are (2) forum posts on topic to your question:
May this be of Good Help;
#3 已发布: 2025/3/19 21:25:59
DM
DM
0个赞,共12个帖子。
Greetings,
Many thanks. For my reference, and so people don't have to follow the links above, is just type Clear(variable1,variable2,etc)=1
Edit: Is there a way to clear all variables without specifying in the ()?
#4 已发布: 2025/3/20 02:12:28
1,443个赞,共2,936个帖子。
Custom Functions plugin has a set of ClearAll() functions.(See here)
sergio 2025/3/20 16:38:00
