Raised Indices
Raised Indices - 消息
#1 已发布: 2012/3/22 23:23:46
Steve Swinbanks
Steve Swinbanks
2个赞,共11个帖子。
I'm sorry if this is a dumb question, but is there a way to have raised indices, just as there is with lowered indices?
Also is there a way to sum over two or more indices?
Thanks
Steve
#2 已发布: 2012/3/23 03:27:53
325个赞和1个踩,共2,052个帖子。
Hello Steve,
I can not see your image, sorry.
The question is, why do you need raised indices? If this is like literal lower index (obtained with dot) I think that raised indices will make confusion with power operator.
I hope I understood your question and yes, there is. You can use summation operator from the palette or loops like "for" or "while". Visit the Wiki, there you will find Tutorials and Examples about it.
#3 已发布: 2012/3/23 04:19:12
Steve Swinbanks
Steve Swinbanks
2个赞,共11个帖子。
Radovan,
Sorry about that, should have read the Wiki more carefully on inserting images. Anyway what I am trying to do is manipulate tensors in General Relativity and need to combine contra and covariant tensors, such as the metric tensor.
Hopefully you can see what I mean in the image below.
Steve
#4 已发布: 2012/3/23 05:41:24
mr_raf
mr_raf
1个赞,共13个帖子。
Hi there.
I guess that for B You should use:
B:sum((el(y,i)^i),i,0,n)
As below
As You see C value is different than You wrote.
Best regards. Rafal
#5 已发布: 2012/3/23 07:36:55
Steve Swinbanks
Steve Swinbanks
2个赞,共11个帖子。
Rafel, thanks, but that is not exactly what I want.
[/img]
As you can see I am after something that expands like contravariant tensors. Not sure if it possible or not.
Steve
#6 已发布: 2012/3/23 07:42:14
mr_raf
mr_raf
1个赞,共13个帖子。
Ok. I thought a little bit, and i think that this should do the trick
Risen_indices - wiki_upload_file
Although still does not have a "nice" (transparent) appearance. Perform calculations correctly.
Something simpler. I went to far with "n" variable.
Risen_indices_2 - wiki_upload_file
Best regards. Rafal
#7 已发布: 2012/3/23 12:08:38
By following this discussion it crossed my mind something. It is quite questionable that this will work in SMath
[MATH=eng]A:sum(el(x,i),i,0,3)[/MATH]
[MATH=eng]A=el(x,0)+el(x,1)+el(x,2)+el(x,3)[/MATH]
But, on the other hand, there is no way that the vector element of x with zero index can get a value, neither numerical nor symbolical. In SMath the minimal matrix index is one but in these cases SMath will not complain if you put any index value.
Do not know how to explain this.
#8 已发布: 2012/3/23 15:00:39
mr_raf
mr_raf
1个赞,共13个帖子。
Hello Radovan.
From what I know matrixes and vectors elements position variable needs to be defined as a positive integers. It is questionable if zero is an integer. In my opinion zero is zero, a strange structure which does not fit into any other sets of numbers.
In Smath as I noticed matrixes and vectors start from number 1. Thats why i used i:=1.
Using i:=0 generates an error, that there is no such element. Which is understandable, because in our vector there is no element [MATH]x,0[/MATH].
Radovan said:
引用
Exacly, using summation of matrix/vector elements alows to put i:=0, but creating matrixes/vectors requires usage of elements number i≥1.
Best regards. Rafal
Radovan Omorjan 2012/3/23 15:24:00
#9 已发布: 2012/3/23 15:35:36
Hello Rafal,
Thanks for the reply. On my second thoughts, I think that nothing is strange if we look at this like a symbolic expression. For instance:
[MATH=eng]sum(el(x,i),i,-3,2)=el(x,-3)+el(x,-2)+el(x,-1)+el(x,0)+el(x,1)+el(x,2)[/MATH]
Therefore, we can accept that symbolic engine accepts any index number, but not numerical. As you sad, only integers greater or equal to 1.
Hope I am right about all of this.
#10 已发布: 2012/3/23 16:05:23
mr_raf
mr_raf
1个赞,共13个帖子。
Hello Rafal,
If we assume that the indicator of the element is a number lying on the axis of integers, and we treat it as an ordinal it seems to me that, yes, ther`s nothing strange.
On the other hand, assuming that it is an element in the first quadrant of the Cartesian, that is part of the real numbers possible to the physical, "touchable" definition, than it is not.
The real thing is to have (n>0) or not have (n=0) an apple, it isn`t physically possible to have negative number of apples (n<0), this statement is a virtual, contractual. While looking at the table You can only say if ther`s an apple (or more apples), or ther`s none. Therefore, while building a vector/matrix, an element can either exist or not, you can not build a matrix for which the indicator of elements will not be possible for defining, that is they will lay in negative part of Cartesian.
I hope that my understanding isn`t wrong.
Best regards. Rafal
#11 已发布: 2012/3/24 20:19:16
Steve Swinbanks
Steve Swinbanks
2个赞,共11个帖子。
Thanks guys for your comments. I tend to agree with Omorr, the indices are only markers and can take any integer form including zero. Anyway it doesn't get me any closer to raised indices so I think I will give that up for the time being.
Steve
