[SSC-3528] Matrix not inserted after :=
[SSC-3528] Matrix not inserted after := - Messages
#1 Posted: 2018/3/30 04:45:28
henry crun
henry crun
0 likes in 34 posts.
If I type
a:
then press the matrix toolbutton, then insert on the row.cols dialog.
Nothing is inserted.
The insertion marker is the reverse-L
If I click on the square to get the normal-L, then it works.
The problem is what Davide shows below.
It is only on Cloud version.
Created by: Andrey Ivashov
Interface translated by: Andrey Ivashov
SMath Studio version: 0.99.6622.8829
Application version: 2.5.6624.1857
Last update: 19.02.2018
SMath Studio in the Cloud is a rich on-line math editor with units and graphs support. No need to install anything on your computer or device - all you need is your favorite web-browser.
It is happening using Opera on Linux, or MS Edge on Win10 or Chrome on Win10.
It does not do it with Studio version on win10.
#2 Posted: 2018/3/30 07:20:38
1,441 likes in 2,932 posts.
Confirmed.
Reported as [SSC-3528]
#3 Posted: 2018/3/30 11:16:06
2,326 likes in 4,013 posts.
Actually I cannot reproduce this issue.
Tried with different local settings - matrix inserted ok after using Insert Matrix dialog.
Please could you create a video, so I could see possible specific things?
#4 Posted: 2018/3/30 11:25:02
NDTM Amarasekera
NDTM Amarasekera
130 likes in 352 posts.
f I type
a:
I too don't get any such behavior.
Latest SS 6661 works perfect in this case.
#5 Posted: 2018/3/30 12:38:39
Seems not always reproduible ... tomorrow I was able to reproduce immediatly, now only every once in a while (Firefox 59.0.2)
#6 Posted: 2018/4/2 18:24:35
henry crun
henry crun
It is exactly as Davide shows above.
Problem the same with browsers: Opera on Linux, Edge on Win10, Chrome on Win10
#7 Posted: 2018/4/3 10:05:47
Andrey, ndtma reported no such bug.
So, Smath is OK, problem is with download.
In short: you can't get a 10 x 2 matrix from the palette, is it ???
#8 Posted: 2018/4/4 00:44:19
henry crun
henry crun
Seems unlikely ndtma was using the Cloud version (which is what I report the bug in) as it the version numbers don't match.
If he was using the cloud version, then different places or different instances are getting different versions served by the cloud service.
#9 Posted: 2018/4/4 11:46:22
NDTM Amarasekera
NDTM Amarasekera
Sorry, It is not the Cloud version I was referring to.
