1 Pages (4 items)
Correction windows and results window - Smath Studio - Messages
Dear All,
I would like to ask you, what it is for and how the following characteristics:
* Correction windows
* Results window
I would like to know how to use them, maybe it will help me improve my experience with Smath Stadium, which is great at the moment. Incredible program.
Thanks and regards
JuanMa
* Results window
Thanks and regards
JuanMa
The Debug window (correction) shows the currently available definitions (the context) if you execute your sheet in debug mode (stepwise) by pressing F11.
The output window shows the results of embedded trace(exp) commands. Exp is any expression. The function can be used anywhere on the sheet (then you need to write trace(): in order to execute it) or in any program (then the statement trace(exp) will do).
See section 10.3 of the german handbook (google for Kraska SMath Handbuch).
Hello Martin, thanks for the contribution and thanks also for the recommendation of the manual, it is very good. Let's learn German!
Cheers
JuanMa
Cheers
JuanMa
WroteHello Martin, thanks for the contribution and thanks also for the recommendation of the manual, it is very good. Let's learn German!
Cheers
JuanMa
Feel free to use online translation tools. Years ago, a forum user was able to produce an english version of the pdf using some cloud service. Quality seemed to be reasonable, except for particular names of UI items or functions, where the back-translation might be different to the original terms.
The handbook was meant as a reference for our students, who sometimes have amaizingly poor knowledge of English.
1 Pages (4 items)
