[MONO] crash on raspberry pi
[MONO] crash on raspberry pi - Installation errors on raspberry pi - 消息
#1 已发布: 2016/12/2 18:56:02
alan
alan
0个赞,共1个帖子。
mono and libmono-winforms2.0-cil installed OK
downloaded stable version and unpacked.
Starts toload page 1 of Smath and then crashes with the following error
~/SMath_Studio $ ./smathstudio_desktop_mono
- [AppDir] Special Functions 1.11.6179.21442 (32 ms.)
- [AppDir] HTML Export 1.13.6179.21442 (3 ms.)
- [AppDir] Export to image 1.9.6179.21448 (2 ms.)
- [AppDir] Picture Region 1.10.6179.21444 (11 ms.)
- [AppDir] Plot Region 1.9.6179.21450 (12 ms.)
- [AppDir] SMath Studio Files Plugin 1.9.6179.21450 (2 ms.)
- [AppDir] Text Region 1.10.6179.21446 (5 ms.)
- [AppDir] SMath Viewer Files Plugin 1.1.6179.21450 (2 ms.)
- [AppDir] XMCD Files Plugin 1.12.6179.21446 (4 ms.)
* Assertion at mini-codegen.c:807, condition `i == sel' not met
Stacktrace:
  at <unknown> <0xffffffff>
  at System.Windows.Forms.TextBoxBase.Draw (System.Drawing.Graphics,System.Drawing.Rectangle) <0x000ab>
  at System.Windows.Forms.TextBoxBase.OnPaintInternal (System.Windows.Forms.PaintEventArgs) <0x00063>
  at System.Windows.Forms.Control.WmPaint (System.Windows.Forms.Message& <0x0017f>
  at System.Windows.Forms.Control.WndProc (System.Windows.Forms.Message& <0x00217>
  at System.Windows.Forms.TextBoxBase.WndProc (System.Windows.Forms.Message& <0x00313>
  at System.Windows.Forms.TextBox.WndProc (System.Windows.Forms.Message& <0x001d3>
  at System.Windows.Forms.Control/ControlWindowTarget.OnMessage (System.Windows.Forms.Message& <0x0002b>
  at System.Windows.Forms.Control/ControlNativeWindow.WndProc (System.Windows.Forms.Message& <0x0003b>
  at System.Windows.Forms.NativeWindow.WndProc (intptr,System.Windows.Forms.Msg,intptr,intptr) <0x0028b>
  at System.Windows.Forms.XplatUIX11.DispatchMessage (System.Windows.Forms.MSG& <0x00023>
  at System.Windows.Forms.XplatUI.DispatchMessage (System.Windows.Forms.MSG& <0x0002b>
  at System.Windows.Forms.Application.RunLoop (bool,System.Windows.Forms.ApplicationContext) <0x00ac7>
  at System.Windows.Forms.Application.Run (System.Windows.Forms.ApplicationContext) <0x0005f>
  at System.Windows.Forms.Application.Run (System.Windows.Forms.Form) <0x0002b>
  at .. (string[]) <0x00273>
  at (wrapper runtime-invoke) <Module>.runtime_invoke_void_object (object,intptr,intptr,intptr) <0xffffffff>
Native stacktrace:
Debug info from gdb:
[New LWP 3906]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
0x76e39ef8 in __libc_waitpid (Cannot access memory at address 0x3
pid=3909, stat_loc=0x7e95ab28, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:40
40	../sysdeps/unix/sysv/linux/waitpid.c: No such file or directory.
  Id   Target Id         Frame
  2    Thread 0x7693f430 (LWP 3906) "mono" 0x76e37a40 in do_futex_wait (isem=isem@entry=0x3181a4) at ../nptl/sysdeps/unix/sysv/linux/sem_wait.c:48
* 1    Thread 0x76f50000 (LWP 3905) "mono" 0x76e39ef8 in __libc_waitpid (Cannot access memory at address 0x3
Thread 2 (Thread 0x7693f430 (LWP 3906)):
#0  0x76e37a40 in do_futex_wait (isem=isem@entry=0x3181a4) at ../nptl/sysdeps/unix/sysv/linux/sem_wait.c:48
#1  0x76e37af4 in __new_sem_wait (sem=0x3181a4) at ../nptl/sysdeps/unix/sysv/linux/sem_wait.c:69
#2  0x00219f98 in mono_sem_wait ()
#3  0x0019091c in ?? ()
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 1 (Thread 0x76f50000 (LWP 3905)):
#0  0x76e39ef8 in __libc_waitpid (pid=3909, stat_loc=0x7e95ab28, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:40
#1  0x000c0ba4 in ?? ()
Got a SIGABRT while executing native code. This usually indicates
a fatal error in the mono runtime or one of the native libraries
used by your application.
Aborted
#2 已发布: 2017/8/26 15:47:26
Mikhail
Mikhail
1个赞,共2个帖子。
I have all the same. But, I tried to run SmathStudio through the debugger in the Mono Develop and it works as expected.
It is possible that this is a bug in the libraries of mono for Raspbian (imho)
#3 已发布: 2017/8/27 18:51:53
Mikhail
Mikhail
1个赞,共2个帖子。
The problem was solved by updating mono from version 3.2.8 to version 5.2.0.215.
The upgrade described here: https://blog.luppes.com/2015/03/19/mono-on-raspberry-pi/
显示剧透
While SmathStudio works as expected.
Davide Carpi 2017/8/27 19:03:00
