Beta: SMath Studio 0.99.6984 (14 February 2019)
Beta: SMath Studio 0.99.6984 (14 February 2019) - 消息
#1 已发布: 2019/2/14 17:00:49
2,344个赞,共4,057个帖子。
组: Super Administrator
它提供了众多的计算功能和丰富的用户界面,并支持约40种语言。该应用程序还内置了数学参考手册。
应用程序可根据您的需求轻松扩展。内置的“扩展管理器”工具让您可以获取数百种官方及第三方资源,涵盖以下类型:使用示例、插件、基于 SMath Viewer 的应用程序、代码片段、界面翻译、交互式书籍、手册以及教程。
下载
SMathStudioDesktop.0_99_6984.Mono.tar.gz (1.36 MiB)已下载 2627 次。
SMathStudioDesktop.0_99_6984.Setup.msi (2.23 MiB)已下载 4975 次。
7位用户喜欢此帖子
Davide Carpi 2019/2/18 20:37:00, frapuano 2019/2/14 19:20:00, NDTM Amarasekera 2019/2/15 02:27:00, Radovan Omorjan 2019/2/15 02:57:00, Serg 2019/2/15 03:13:00, sergio 2019/2/15 05:57:00, Вячеслав Мезенцев 2019/2/14 17:48:00
#2 已发布: 2019/2/15 03:29:02
genf
genf
6个赞,共72个帖子。
Спасибо. Теперь функции работают значительно быстрее.
Вернулась старая проблема с настройками страницы - не сохраняются настройки при нажатии на кнопку "Использовать по-умолчанию".
Вернее они для файла сохраняются, но показывает, что не сохранились.
А вот глобально не сохраняются.
Небольшое кино
#3 已发布: 2019/2/15 06:48:04
fedeghi
fedeghi
25个赞,共112个帖子。
Hi Andrey,
since I'm using SMath mainly for office work, I'm always struggling between the temptation of "instant updating" to the latest (even if beta) build in order to have all the new cool features, and the conservative approach to wait for the official stable release and stay safe with my library of .sm files.
Up to now, I have been able to resist and stay on the safe path, but the "dark side is calling"
Recently a lot of nightly builds have been issued, so I'm wondering if you are planning to upload in a short time a stable release to consolidate all the updates that have been placed here and there in the betas?
Or do you think that a stable release will not follow shortly?
In other words, in case a stable release is not planned in the upcoming weeks, I might think to update on a backup machine and test the existing files there.
Infact, there are some features which I'd like to use (i.e. upgraded syntax highlighting, etc..)
#4 已发布: 2019/2/15 06:53:08
1,443个赞,共2,936个帖子。
You can always download the Mono.tar.gz package and go for a portable test version
Serg 2019/2/15 09:09:00
#5 已发布: 2019/2/15 09:10:40
genf
genf
6个赞,共72个帖子。
Да, это действительно удобно. Портативную версию уже использую лет 5
#6 已发布: 2019/2/15 14:13:20
2,344个赞,共4,057个帖子。
Так а сохранение размера бумаги я и не делал Сохраняется только ориентация страниц, колонтитулы и т.п. С размером были какие-то проблемы. Как-нибудь посмотрю туда ещё раз...
#7 已发布: 2019/2/15 14:29:16
2,344个赞,共4,057个帖子。
Hello.
The reason of why we have so many beta versions since latest available stable is that there are several major changes were done to the logic of saving/opening files and rendering Worksheets.
These changes must be tested well before going to the wild world
As for today I see no any new significant errors reported + all automated tests I have are also passed ok, so I'm thinking about latest nightly builds as about release candidates. These versions seems stable enough to use them.
Regarding next stable release - I plan to publish it on 1-st March. The main reason of it is that I need to test/prepare Cloud version as well as iOS/Android/UWP versions to make one-shot-release. There are plenty of work to perform...
3位用户喜欢此帖子
Serg 2019/2/15 15:03:00, sergio 2019/2/15 15:25:00, frapuano 2019/2/15 14:54:00
#8 已发布: 2019/2/15 18:25:24
fedeghi
fedeghi
25个赞,共112个帖子。
Thanks for the info! :d
#9 已发布: 2019/2/18 15:06:04
2,344个赞,共4,057个帖子。
Реализовано тут: https://en.smath.com/forum/yaf_postst17120_Beta--SMath-Studio-0-99-6988--18-February-2019.aspx
Serg 2019/2/25 15:15:00
#10 已发布: 2019/2/25 15:29:20
genf
genf
6个赞,共72个帖子。
Бывает в версии 6984 при открытии файла происходит очень долгий расчет ... приходится прерывать и обновлять - при обновлении все быстро считается.
См. кино
Как правило такие долгие расчеты происходят при первом открытии файла, но не всегда.
Это исправлено в 6988?
