Pipe Network Analysis
Pipe Network Analysis - Solution by loop method - 消息
#1 已发布: 2016/4/14 02:36:18
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
Examples of a problem solved in SS and Excel are attached.
The results are tallying.
Pipe Network Ex3.1.sm (417.66 KiB)已下载 1809 次。
Pipe Network by Solver Ex3.xlsx (301.19 KiB)已下载 1274 次。
Alexander O. Melnik 2016/4/14 14:10:00
#2 已发布: 2016/4/14 03:15:44
Alexander O. Melnik
Alexander O. Melnik
127个赞,共498个帖子。
IMHO, in this case the EXCEL solution is "cleaner".
EXCEL shines when you need to process simple formulae applicable to many rows of data... Which we do have in this case.
#3 已发布: 2016/4/14 10:47:43
983个赞,共6,866个帖子。
The problem is not to insist to expand symbolic. If you were scared of that one,
you have seen nothing compared to > 12 pages wide expansion. Before expanding,
hover Unknown(F) and see if it is of any profitable use.
Davide Carpi 2016/4/14 15:22:00
#4 已发布: 2016/4/14 10:49:59
983个赞,共6,866个帖子。
... forgot to attach WS.
Pipe Network.sm (194.18 KiB)已下载 1597 次。
2位用户喜欢此帖子
Davide Carpi 2016/4/14 15:22:00, frapuano 2016/4/14 17:15:00
#5 已发布: 2016/5/2 22:10:30
Gilberto E. Urroz
Gilberto E. Urroz
23个赞,共36个帖子。
Check out Lectures 14b-20 in this website:
http://www.neng.usu.edu/cee/faculty/gurro/Classes/Classes_Spring2013/CEE3510_Spring2013/CEE3510_Schedule.htm
EPANET is the easiest way to solve pipe networks
#6 已发布: 2016/5/3 10:53:06
Ruben Sidranski
Ruben Sidranski
17个赞,共465个帖子。
Multiple software to do this. Pipe-flo, AFT Fathom, and others come to mind. If memory serves, the hydraulic institute and a limited node software to do this too.
http://www.pumps.org/Training/Free_Pump_Software.aspx
With that said, I still like to do things on SMath/MathCAD to verify results, since I can "see" the math.
#7 已发布: 2016/5/3 11:32:51
983个赞,共6,866个帖子。
Can't be more right than checking the maths for documenting the project(s).
Elsid, as a byside question: is your Mathcad 15 working ?
My Google web site is still active "mathengjmg". I can see it all, but
since PTC deactivated [scrapped] Mathcad 11 Single User Edition, if I
download any of the 663 work sheets [100MB], none will open.
Would you be kind enough to download some work seets and let me know
if they open in your Mathcad 15 ?
Thanks, Jean
https://sites.google.com/site/mathengjmg[/url]
#8 已发布: 2016/5/3 13:59:56
Ruben Sidranski
Ruben Sidranski
17个赞,共465个帖子。
Jean,
I sent private Message
#9 已发布: 2016/5/3 20:09:00
983个赞,共6,866个帖子。
Jean,
Thanks Elsid, I replied.
