Suggestions for possible Numerical Integration plug-in
Suggestions for possible Numerical Integration plug-in - 消息
#1 已发布: 2010/9/11 18:25:09
frapuano
frapuano
13个赞,共115个帖子。
Hi Andrey,
I would like to develop - hoping to be able to do this - someting for Smath Studio and my idea is toward the development of a Numerical Integration plug-in.
What I would like to know is if you or someone else is already trying to do something in this area or plan to expand Smath with further features on this side in the short future just to avoid duplicating the efforts.
Moreover if this is not the case I would like to know what is your suggestion on the best approach to follow to develop something in this area . My esperiences are limited to Excel VBA development and I would like to know if in your opinion is better to try the integration in a plug-in of an already available library ( for istance the ALGLIB one; that looks to me very good and available in VBA ) or instead to develop/design something from scratch putting inside other aspect like the possibility to handle multiple integrals and the Monte Carlo methods too.
Sorry for the newbie questions , but this is just to understand better which is in your opinion about the best development pathway to follow based on your wider experience on this side .
Francesco
#2 已发布: 2010/9/11 20:18:39
2,344个赞,共4,057个帖子。
组: Super Administrator
Hello Francesco.
I don't know about any attempt to create or improve numerical integration algorithm of SMath Studio.
...I would like to know if in your opinion is better to try the integration in a plug-in of an already available library ( for istance the ALGLIB one; that looks to me very good and available in VBA ) or instead to develop/design something from scratch putting inside other aspect like the possibility to handle multiple integrals and the Monte Carlo methods too.
I think that this is easier to create a new plugin with new function realization. Then if you will not mind we can import your realization into the existing SpecialFunctions plugin, but this is fully up to you. I suggest to handle function like extInt("function", "variable", "lowerLimit", "upperLimit") (or any other name you prefer) and work to solve the integral. When you will finish it just say me and I will help you to implement user-friendly graphical representation of this function like you can see for current int(..) function.
And of course, if you'll need any help let us know here.
Best regards, Andrey Ivashov.
#3 已发布: 2010/9/16 08:01:38
frapuano
frapuano
13个赞,共115个帖子。
Hello Andrey
In this period I have collected and studied the problem of numerical integration and I have seen that it is really a wide area of math in which is easy to get lost.
So I have for now limited my purpose to the numerical integration of functions of one variable using non adaptative algorithms.
I have found some solutions already implemented using Gauss quadrature method and have tested it in .....Excel that is the development environment I am more familiar with.
Function GaussInt(Func As String, ParamA As Variant, ValueA As Variant, IntA As Variant)
    Dim TOL As Double, Eform As String, LLim As Double, ULim As Double
    Dim Result(1 To 1, 1 To 4) As Double, IERR As Long, ErrVal As Double
    Dim XA() As Double, WA() As Double, EStep As String, Nnodes As Variant
    Dim OldArea As Double, Area As Double, MaxLoops As Long
    Dim I As Long, J As Long, K As Long, N As Long, IntAUB As Long
    Dim X_1 As Double, x_3 As Double, X_2 As Double, W_2 As Double, SArea As Double
    Dim W As Double
    Result(1, 4) = MicroTimer
    GetArray ParamA
    GetArray ValueA
    GetArray IntA
    IntAUB = UBound(IntA) - LBound(IntA) + 1
    If IntAUB < 3 Then
        GaussInt = "Invalid IntA"
        Exit Function
    End If
    Eform = Func
    For I = 1 To UBound(ParamA, 1) - LBound(ParamA, 1) + 1
        Eform = Replace(Eform, ParamA(I, 1), ValueA(I, 1))
    Next I
    LLim = IntA(2, 1)
    ULim = IntA(3, 1)
    If IntAUB > 3 Then TOL = IntA(4, 1) Else TOL = 0.0000000001
    If IntAUB > 4 Then MaxLoops = IntA(5, 1)
    If IsEmpty(MaxLoops) = True Or MaxLoops < 2 Then MaxLoops = 10
    If IntAUB > 5 Then Nnodes = IntA(6, 1) Else Nnodes = 12
    If Nnodes = "" Or Nnodes < 2 Or Nnodes > 12 Then Nnodes = 12
    ReDim XA(1 To Nnodes)
    ReDim WA(1 To Nnodes)
    IERR = GetGaussA(Nnodes, XA(), WA())
    OldArea = 0
    N = 1
    For K = 1 To MaxLoops    ' Double the number of steps up to MaxLoops times
        Area = 0
        W = (ULim - LLim) / N
        For I = 1 To N
            X_1 = LLim + (I - 1) * W
            x_3 = X_1 + W
            X_2 = (x_3 + X_1) / 2
            W_2 = (x_3 - X_1) / 2
            For J = 1 To Nnodes
                EStep = Replace(Eform, IntA(1, 1), X_2 + W_2 * XA(J))
                SArea = Evaluate(EStep)
                Area = Area + WA(J) * SArea
            Next J
        Next I
        Area = Area * W_2
        ErrVal = Abs((Area - OldArea) / Area)
        If ErrVal < TOL Then GoTo Finish
        OldArea = Area
        N = 2 * N
    Next K
    K = K - 1
Finish:
    Result(1, 1) = Area
    Result(1, 2) = ErrVal
    Result(1, 3) = K
    Result(1, 4) = MicroTimer - Result(1, 4)
    GaussInt = Result
End Function
Public Sub GetArray(arrayname)
    Dim TEMP As Variant
    If TypeName(arrayname) = "Range" Then
        If arrayname.Rows.Count = 1 Then
            If arrayname.Columns.Count = 1 Then
                arrayname = Array(arrayname.Value2)
                TEMP = arrayname(0)
                ReDim arrayname(1 To 1, 1 To 1)
                arrayname(1, 1) = TEMP
            Else
                arrayname = WorksheetFunction.Transpose(arrayname)
            End If
        Else
            arrayname = arrayname.Value2
        End If
    ElseIf Not IsArray(arrayname) Then
        arrayname = Array(arrayname)
    Else
    End If
End Sub
Function GetGaussA(Nnodes, ByRef XA, ByRef WA) As Long
    Select Case Nnodes
    Case 2
        XA(1) = -0.577350269189626
        XA(2) = 0.577350269189626
        WA(1) = 1
        WA(2) = 1
    Case 3
        XA(1) = -0.774596669241483
        XA(2) = 0
        XA(3) = 0.774596669241483
        WA(1) = 0.555555555555555
        WA(2) = 0.888888888888889
        WA(3) = 0.555555555555555
    Case 4
        XA(1) = -0.861136311594053
        XA(2) = -0.339981043584856
        XA(3) = 0.339981043584856
        XA(4) = 0.861136311594053
        WA(1) = 0.347854845137453
        WA(2) = 0.652145154862546
        WA(3) = 0.652145154862546
        WA(4) = 0.347854845137453
    Case 5
        XA(1) = -0.906179845938664
        XA(2) = -0.538469310105683
        XA(3) = 0
        XA(4) = 0.538469310105683
        XA(5) = 0.906179845938664
        WA(1) = 0.236926885056189
        WA(2) = 0.478628670499366
        WA(3) = 0.568888888888889
        WA(4) = 0.478628670499366
        WA(5) = 0.236926885056189
    Case 6
        XA(1) = -0.932469514203152
        XA(2) = -0.661209386466265
        XA(3) = -0.238619186083197
        XA(4) = 0.238619186083197
        XA(5) = 0.661209386466265
        XA(6) = 0.932469514203152
        WA(1) = 0.171324492379171
        WA(2) = 0.360761573048138
        WA(3) = 0.467913934572691
        WA(4) = 0.467913934572691
        WA(5) = 0.360761573048138
        WA(6) = 0.171324492379171
    Case 7
        XA(1) = -0.949107912342759
        XA(2) = -0.741531185599395
        XA(3) = -0.405845151377397
        XA(4) = 0
        XA(5) = 0.405845151377397
        XA(6) = 0.741531185599395
        XA(7) = 0.949107912342759
        WA(1) = 0.129484966168869
        WA(2) = 0.279705391489278
        WA(3) = 0.381830050505117
        WA(4) = 0.417959183673472
        WA(5) = 0.381830050505117
        WA(6) = 0.279705391489278
        WA(7) = 0.129484966168869
    Case 8
        XA(1) = -0.960289856497536
        XA(2) = -0.796666477413627
        XA(3) = -0.525532409916329
        XA(4) = -0.18343464249565
        XA(5) = 0.18343464249565
        XA(6) = 0.525532409916329
        XA(7) = 0.796666477413627
        XA(8) = 0.960289856497536
        WA(1) = 0.101228536290376
        WA(2) = 0.222381034453374
        WA(3) = 0.313706645877887
        WA(4) = 0.362683783378361
        WA(5) = 0.362683783378361
        WA(6) = 0.313706645877887
        WA(7) = 0.222381034453374
        WA(8) = 0.101228536290376
    Case 9
        XA(1) = -0.968160239507626
        XA(2) = -0.836031107326637
        XA(3) = -0.61337143270059
        XA(4) = -0.324253423403808
        XA(5) = 0
        XA(6) = 0.324253423403808
        XA(7) = 0.61337143270059
        XA(8) = 0.836031107326635
        XA(9) = 0.968160239507627
        WA(1) = 8.12743883615759E-02
        WA(2) = 0.180648160694854
        WA(3) = 0.260610696402935
        WA(4) = 0.312347077040002
        WA(5) = 0.330239355001259
        WA(6) = 0.312347077040002
        WA(7) = 0.260610696402935
        WA(8) = 0.180648160694857
        WA(9) = 8.12743883615721E-02
    Case 10
        XA(1) = -0.973906528517172
        XA(2) = -0.865063366688984
        XA(3) = -0.679409568299024
        XA(4) = -0.433395394129247
        XA(5) = -0.148874338981631
        XA(6) = 0.148874338981631
        XA(7) = 0.433395394129247
        XA(8) = 0.679409568299024
        XA(9) = 0.865063366688984
        XA(10) = 0.973906528517172
        WA(1) = 6.66713443086868E-02
        WA(2) = 0.149451349150573
        WA(3) = 0.219086362515983
        WA(4) = 0.269266719309996
        WA(5) = 0.295524224714752
        WA(6) = 0.295524224714752
        WA(7) = 0.269266719309996
        WA(8) = 0.219086362515983
        WA(9) = 0.149451349150573
        WA(10) = 6.66713443086868E-02
    Case 11
        XA(1) = -0.97822865814604
        XA(2) = -0.88706259976812
        XA(3) = -0.730152005574042
        XA(4) = -0.519096129206811
        XA(5) = -0.269543155952344
        XA(6) = 0
        XA(7) = 0.269543155952344
        XA(8) = 0.519096129206811
        XA(9) = 0.73015200557405
        XA(10) = 0.887062599768093
        XA(11) = 0.978228658146058
        WA(1) = 5.56685671162158E-02
        WA(2) = 0.125580369464874
        WA(3) = 0.18629021092774
        WA(4) = 0.233193764591992
        WA(5) = 0.262804544510246
        WA(6) = 0.2729250867779
        WA(7) = 0.262804544510246
        WA(8) = 0.233193764591993
        WA(9) = 0.186290210927733
        WA(10) = 0.125580369464913
        WA(11) = 5.56685671161695E-02
    Case 12
        XA(1) = -0.981560634246732
        XA(2) = -0.904117256370452
        XA(3) = -0.769902674194317
        XA(4) = -0.587317954286614
        XA(5) = -0.36783149899818
        XA(6) = -0.125233408511468
        XA(7) = 0.125233408511468
        XA(8) = 0.36783149899818
        XA(9) = 0.587317954286614
        XA(10) = 0.769902674194317
        XA(11) = 0.904117256370452
        XA(12) = 0.981560634246732
        WA(1) = 4.71753363864754E-02
        WA(2) = 0.106939325995363
        WA(3) = 0.160078328543358
        WA(4) = 0.203167426723067
        WA(5) = 0.233492536538353
        WA(6) = 0.249147045813402
        WA(7) = 0.249147045813402
        WA(8) = 0.233492536538353
        WA(9) = 0.203167426723067
        WA(10) = 0.160078328543358
        WA(11) = 0.106939325995363
        WA(12) = 4.71753363864754E-02
    End Select
End Function
The problem now it trying to traslate this functions in VB Express programs ; class module as explained in your tutorial.
I have read it and downloaded the VB Express IDE but I am a little bit intimidated by this new development environment.
So I have a little bit of questions to ask:
In developing a numerical integration program is necessary to input same informations:
1-The algebraic expression of the function to integrate ( a text string)
2-The variable of integration ( a text string )
3-The integration extremes ( numbers )
now in Excel I have cells where to load these informations as text string and then internally using the trick of the evaluate method I can for different values of the variable of integration calculate the corresponding values of the function to integrate.
What in my ignorance I am not able to reproduce ( for now ) in VB express is this first steps.
In particular the one of analyzing the string that describes the Integral function and turn it in something that can be computed changing the values of the variable of integration.
What I wold like to know is if I need to develop a math parser for this task or is something - as I guess - that is already implemented in Smath and so I need only to understand how I can access this internal description and how to use it for the number crunching algorithm.
Because you have already developed a definite integral class/routine would be nice - if possible - to see how this conversion is implemented or how I can access the results of this conversion to use for further calculations.
If is not possible to have these info's/part of code it would be enough to have just the header of the actual routine and the returning part so that I can focuse my attention to the core part that is related to the numerical integration only.
Moreover I am not a class oriented but a more brutal stright to the result VBA programmer and this is creating me a quite steep learning curve in this new development environment.
Sorry again for my newbie questions and best regards
Francesco
#4 已发布: 2010/9/16 11:31:43
maweilian
maweilian
5个赞,共103个帖子。
Andrey,
Has there been any progress in the documentation of the Smath object model? This would really help Francesco and others (including myself) to begin to understand how to use the objects, methods, and properties of the Smath API. Or if you could come up with some more example videos that demonstrate key knowledge areas. Anything would help. At this point, we are mostly groping in the dark with regard to the Smath API.
Will
P.S. maybe you could release an incomplete version of the object model documentation that focuses on just the key knowledge areas (those that would probably be needed for Francesco's integration plugin and the improved solve function that I am working on).
#5 已发布: 2010/9/20 21:18:05
2,344个赞,共4,057个帖子。
Hello.
Sorry guys, just have no time to provide detailed answers this time
Documenting still in progress now, but ok, I will release current version with a next SMath Studio beta. Can't do it for 0.89 because it will take many time to revert everything to the 0.89 release date and to generate those small prepared part of comments.
Regards.
