Reservoir Flood Capacity Estimation
Reservoir Flood Capacity Estimation - Basic approach to calculate capacity of a reservoir to absorb a given flood - 消息
#1 已发布: 2015/12/29 07:16:29
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
The attached file shows basic steps involved in estimating the capacity of a proposed reservoir to absorb a flood of a given return period.
The required data are (a) Inflow Hydrograph and (b) Elevation/Area (Topography of the reservoir site).
The reservoir has a bottom outlet which can release a maximum of 200 cumec to prevent inundation of a nearby town area downstream of the proposed reservoir.
This is based on a project study undertaken in Sri Lanka.Reservoir Flood Capacity Estimation.sm (188.6 KiB)已下载 1665 次。
3位用户喜欢此帖子
Radovan Omorjan 2015/12/29 10:23:00, Davide Carpi 2015/12/29 13:03:00, overlord 2016/4/8 08:20:00
#2 已发布: 2015/12/29 10:28:02
325个赞和1个踩,共2,052个帖子。
Very impressive, thank you
Just a small typo after the definition of function CtoE(x,X), I think. The call is CtoL(x,CC) (L instead of E)
#3 已发布: 2015/12/29 11:16:37
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
Thank you.
#4 已发布: 2015/12/29 23:22:13
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
Many thanks to omorr for pointing out the typo in call to CtoL(x,CC), next to the definition of the function CtoE(x,X).
It should be corrected as CtoE(x,CC).The result will be CtoE(x,CC)=60m, where CC has been defined as 150 MCM.
Sorry for the inconvenience.
#5 已发布: 2016/4/8 08:21:25
600个赞,共1,381个帖子。
integral isn't calculated in this example. Culprit is maxima plugin. If it is installed you can't get a result.
#6 已发布: 2016/4/8 08:43:08
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
http://en.smath.info/forum/yaf_postst7429_Definite-Integration-of-the-Exponential-Function.aspx
Thanks. This has been discussed.
#7 已发布: 2016/4/8 14:48:36
983个赞,共6,866个帖子。
Integral works for me:
You are totalising an hourly rate of accumulation
over the [a,b] time limits for a total MCM [m^3]
