Ellipse and... go to bugs
Ellipse and... go to bugs - Is it one SMath bug? - Messages
#1 Posted: 2023/9/7 11:05:14
Valery Ochkov
Valery Ochkov
66 likes in 682 posts.
My students were building a multifocal ellipse and... almost went crazy. My ellipse is correct, but the student's is incorrect. Although the formulas are the same.
Can you guess where the error is and whether it is necessary to modify SMath so that such an error is visible?
Do you know more some examples?
Ellipse4.sm (11.6 KiB) downloaded 1365 time(s).
#2 Posted: 2023/9/7 11:47:49
126 likes in 341 posts.
In fact only apparently the written formula is the same but in the first case "S" is outside the summation while in the second case it is inside the summation. You can verify this by copying and pasting the two formulas into a text editor.
Show Spoiler
Valery Ochkov 2023/9/7 13:42:00
#3 Posted: 2023/9/7 11:58:54
Arie
Arie
94 likes in 285 posts.
Further illustrated by adding parenthesis around the summation in each formula
Show Spoiler
#4 Posted: 2023/9/7 12:00:34
1,441 likes in 2,932 posts.
Show Spoiler
You can also select/double-click the sum symbol to check what belongs to it.
sergio 2023/9/7 12:26:00, Valery Ochkov 2023/9/7 13:42:00
#5 Posted: 2023/9/7 12:01:59
Oscar Campo
Oscar Campo
135 likes in 309 posts.
The problem is that in the first Ellipse(x,y) definition, variable S is outside Sum function, but in the definition of your students is inside:
Your definition:
Ellipse(x,y):sum(sqrt((x-el(X.F,i))^2+(y-el(Y.F,i))^2),i,1,N)-S
Student´s definition:
Ellipse(x,y):sum(sqrt((x-el(X.F,i))^2+(y-el(Y.F,i))^2)-S,i,1,N)
Maybe, this explicit form is most clear for students:
#6 Posted: 2023/9/7 13:43:13
Valery Ochkov
Valery Ochkov
Better so
Davide Carpi 2023/9/8 06:52:00
#7 Posted: 2023/9/7 14:24:15
1,106 likes in 1,784 posts.
Better so ...
You can tell your students that you are using the Note under Example 3 of point 7.1.3 of ISO 80000-1:2009(E) Quantities and units, Part 1: General.
#8 Posted: 2023/9/7 15:28:30
Valery Ochkov
Valery Ochkov
It if Mathcad 15
1 ln(x)
2 ln*x - why not
