RC3: SMath Studio 0.98.5918 (15 March 2016)
RC3: SMath Studio 0.98.5918 (15 March 2016) - Messages
#1 Posted: 2016/3/15 13:32:04
2,326 likes in 4,013 posts.
SMath Studio 0.98.5918 available
Latest changes (against SMath Studio 0.98.5914)
  • SS-125: Inserting Chinese symbols fixed;
  • SS-2305: Situations when it was impossible to paste part of the equation into another equation fixed;
  • SS-2280: Graphic glitch in Extension Manager form on plugin uninstall fixed;
  • SS-2298: Exception on pressing Open button from Donate dialog fixed;
  • SS-206: Unexpected worksheet scrolling on pressing Delete/Backspace when cursor is in the right part of equation fixed;
  • SS-112: Fixed issues when it was impossible to open file because of incorrect color specified in file content;
  • SS-35: Missing tooltips from side panel fixed;
  • SS-51: Issue partially handled: behavior is correct in case of work with one collapsed area - space will be adjusted automatically;
  • Implemented ability to specify printer name when printing from command prompt;
  • Worksheet evaluation starts now on print or export from command prompt (required to update regions states to display them correctly).
Download
9 users liked this post
NDTM Amarasekera 2016/3/15 13:39:00, ioan92 2016/3/15 13:42:00, frapuano 2016/3/15 13:55:00, Davide Carpi 2016/3/15 13:57:00, уни 2016/3/15 14:02:00, sergio 2016/3/15 14:42:00, Alexander O. Melnik 2016/3/15 17:58:00, Mike Kaganski 2016/3/16 00:57:00, Radovan Omorjan 2016/3/16 02:53:00
#2 Posted: 2016/3/15 23:52:19
Igor Skarine
Igor Skarine
14 likes in 97 posts.
roots2polynomial.sm (15.99 KiB) downloaded 1271 time(s).
Hi Andrey,
The worksheet in attachment doesn't work in 0.98, but works fine in 0.97.
The error message is "s - not defined". It's bothering me, because of I've used the functions in several documents.
Another issue is that new version 0.98 stays non-responsive for a few minutes when I try to quit SmathStudio.
#3 Posted: 2016/3/16 00:20:33
I'm incompetent wrt your long program w/o example.
Nothing to see => nothing to do. Something to see,
use the solve block ... Works fine J0, J1, Y0, Y1.
Bessel JY.sm (53.41 KiB) downloaded 1292 time(s).
#4 Posted: 2016/3/16 00:55:01
... for the cubic equation, there is in "Samples"
a more robust "Cubic Solver"
#5 Posted: 2016/3/16 01:05:49
... here is EigenAll Companion
eigenAll Companion.sm (39.25 KiB) downloaded 1302 time(s).
#6 Posted: 2016/3/16 01:26:23
Mike Kaganski
Mike Kaganski
184 likes in 434 posts.
You seem to cheat using one-liners that depend on inner order of evaluation. It's not fixed, may change in any new version, so it's unsafe to do that.
Also, you should keep in mind that evaluation defaults to symbolic; so in loops it's often advisable to use eval() to force SMath store direct value to a variable, instead if (sometimes very complex) recursive formula it had stacked up to this point.
roots2polynomial-fixed.sm (16.33 KiB) downloaded 1315 time(s).
С уважением, Михаил Каганский
Igor Skarine 2016/3/16 12:20:00, Davide Carpi 2016/3/16 04:37:00
#7 Posted: 2016/3/16 02:01:31
Mike Kaganski
Mike Kaganski
By the way, Andrey, could you please state on the following questions:
1. Currently, boolean operands are always evaluated regardless if it's already possible to deduce final result. E.g.: (x:=1)V(y:=5) will assign both x and y, despite it's enough to only calc left (or right) part to know the boolean result. Could you please confirm or refute that this will always be so (may I rely on this to create simple (not order-dependent) one-liners?).
2. Currently, boolean operands are evaluated from left to right. E.g.: (x:=1)V(eval(y:=x)) will make y to be 1, while (eval(y:=x))V(x:=1) will give an "Undefined" error. Could you please confirm or refute that this will always be so (may I rely on this to create complex (order-dependent) one-liners?).
Thank you for your work!
#8 Posted: 2016/3/16 14:04:43
Thank you for questions!
...new version 0.98 stays non-responsive for a few minutes when I try to quit SmathStudio.
I think it is because of some plug-in you have installed on your system. Try to close SMath Studio, then rename SMath folder to SMath_temp in %APPDATA%, then start SMath Studio again and try to close it to see how much time closing will take.
It is because of the following string (in two places):
Starting from SMath Studio 0.98 application handles calculation parts from left to right when no other rules to follow. And it became a rule now which will remain the same in future. So you just need to change places for 1-st and 3-rd operations in your matrix:
Sorry for this, but before 0.98 order of operations in such cases was not actually strictly defined.
Correction: it was unsafe. Now it is absolutely legal way to do such operations. A bit tricky, but legal.
Very good question! For some reason (ah, my stupid head) never thought about it. But later better then never... I just did corrections to boolean AND and OR and the final results you can see on the screenshot:
I think, answer is in the screenshot above.
P.S.: I do realize that these changes may result in errors in some existing calculations, but we need to accept these new rules in order to be sure such issues will never appear again in future + rules of a game are now defined.
Best regards!
5 users liked this post
frapuano 2016/3/16 15:57:00, Mike Kaganski 2016/3/16 19:18:00, Igor Skarine 2016/3/16 19:26:00, уни 2016/3/16 14:19:00, Davide Carpi 2016/3/16 14:30:00
#9 Posted: 2016/3/18 11:34:40
Igor Skarine
Igor Skarine
Hi Andrey,
I recently found that my old worksheets that used Jacobian (some non-linear solvers) do not work properly.
To fix the issue I have to add maple(optimize(EXP)) around EXP instead of just EXP.
The good example is old UNI's Draghilev method demo sheet.
#10 Posted: 2016/3/18 14:15:26
Tom,
You may want to try the more general Genfit.
It is independent of Maple. In many cases,
it works better than Mathcad 11, but more
difficult to manipulate ... price to pay.
Visit "Samples" => Genfit ... + examples.
Genfit Pharmacokinetics.sm (38.24 KiB) downloaded 1272 time(s).
#11 Posted: 2016/3/18 17:09:33
... quick construct
