iterator argument of sum/product
iterator argument of sum/product - 消息
#1 已发布: 2016/12/17 15:36:38
983个赞,共6,866个帖子。
... can' t understand what Smath does not like.
Worked so nice 5346 !
Fourier Budapest39 Spectrum.sm (36.68 KiB)已下载 1306 次。
MOD: reduced test file http://en.smath.info/forum/yaf_postsm35790_Stable--SMath-Studio-0-98-6128--11-October-2016.aspx#post35790
#2 已发布: 2016/12/17 16:27:39
325个赞和1个踩,共2,052个帖子。
If you mean on the errors regarding "B92(u)" function and "fit" matrix with the error: "Variable and function names can't start with a number", this is due to the unsolved problem of summation in the B2(u) function. We have to define this function with the line environment, although it is a single line function (summation causes the problem). I really do not know why this problem appeared in the recent versions and when/if is going to be solved.
#3 已发布: 2016/12/18 16:23:38
983个赞,共6,866个帖子。
If you mean on the errors regarding "B39(u)" function and "fit" matrix with the error: "Variable and function names can't start with a number", this is due to the unsolved problem of summation in the B39(u) function. We have to define this function with the line environment, although it is a single line function (summation causes the problem). I really do not know why this problem appeared in the recent versions and when/if is going to be solved.
Thanks Radovan,
You have doctored/rescued the 3 work sheets.
Only B39(u) needs the local line definition.
The A's B's coefficients MUST NOT have local line definitions.
