Black background on text regions when "Save as" HTML
Black background on text regions when "Save as" HTML - Messages
#1 Posted: 2022/2/1 22:49:54
1,106 likes in 1,784 posts.
Text regions appear with a black background when the file is saved as an HTML page. SMath Version 0.99.7921.69
SMath screen capture
HTML output page screen capture
Davide Carpi 2022/2/2 19:25:00
#2 Posted: 2022/2/2 09:18:19
Similar bug including all work sheet regions was reported,
from recollection: not attended ... still existing once in a while.
#3 Posted: 2022/2/2 19:20:58
1,441 likes in 2,932 posts.
Thank you, bug confirmed and fix tested and committed to the repository.
Worksheets with unwanted black background still exists because is a property saved in the affected files, but those are a marginal number and the bug on saving is fixed in recent versions of SMath Studio.
Since black is a valid background color there aren't robust ways to improve the loading of affected files directly on program side (and anything would add a small time penalty on loading for each region in each file, all for a once in a bluemoon case, very noticeable and easily fixable from user-side that single time it happens).
To fix those existing worksheets you can either:
1. open the file, select the black regions and change the background color to transparent;
2. use a batch fix method like those proposed here: https://en.smath.com/forum/yaf_postsm75355_Black-regions.aspx#post75355
Alvaro 2022/2/2 21:50:00, sergio 2022/2/3 09:03:00
