1页(3条)
Database sheet for SMath - Database sheet for SMath - 消息
Hi Andrey,
I am a structural engineer from India. I found SMath while searching on net for an alternative to Mathcad and I am using it for about 3 years. I have a request to add a feature to SMath, which I was thinking for a long time.
I will explain it down:
As you see in the picture above:
As a structural engineer I have sometimes a large number of data as design forces or support reactions or deflections of structural elements.
I think, if the database sheet is available with SMath all those calculations can be easily processed.
I like to hear from you.
Thanks and regards
Shiju.
- SMath with 3 numbers (or more) sheets (like excel).
- One sheet of these 3 will be for a database with cells of rows and columns similar to excel.
- One sheet for custom functions applicable for that workbook.
- One is the main SMath worksheet.
Thanks and regards
Shiju.
Davide Carpi 2015/9/15 19:02:00
shiju,
I agree, this would be a nice feature. In the meantime you could have (2) areas, (1) for inputs and (1) for equations above all of your calcs; its not as glamorous as your proposed idea, but it should obtain the same result.
This feature would be great when implemented. I hope Andrey would grant shiju's request.
Currently, as a work around to the database as part of the Smath sheets, we are using an xlsx plug-in. It's very useful.
1页(3条)
