SMath Studio 0.97.5329 (04 August 2014)
SMath Studio 0.97.5329 (04 August 2014) - 消息
#1 已发布: 2014/8/4 13:13:16
2,344个赞,共4,057个帖子。
组: Super Administrator
New SMath Studio 0.97.5329 available
Last changes (against SMath Studio 0.97.5154)
  • Change units for C, F and Re non-linear units added to package;
  • Built-in variable added: lastError;
  • Support for beta releases of extensions implemented;
  • Donation dialog reworked;
  • Worksheet splitter implemented (vertical and horizontal);
  • ViewerFileType plug-in updated to support full version (BETA);
  • Undo/Redo functionality improved to be more stable;
  • Delete and move operations improved for Collapsed Areas;
  • Behavior of combobox for changing font size improved;
  • Unit Package updated (new units added);
  • Insert Unit dialog improved to allow displaying properties as dimensions if defined.
  • Silent mode of the application improved;
  • Monospace font applied to Output window;
  • Key presses handling improved;
  • SS-2: Fixed issues with lost regions under bottom Area part after save to SM/SMZ file;
  • SS-10: Critical simplification issue fixed (happens sometimes on complex math expressions);
  • SS-36: Fixed issue when changes are lost if a link is followed;
  • SS-37: File name update in window title upon jumping to link target;
  • SS-39: Added "Default" item added to Fractions options for MathRegion;
  • SS-40: Approach to handle invisible empty text subscripts corrected;
  • SS-52: Support for sech() and csch() functions added to differentiation engine;
  • SS-54: Description text is always black now;
  • SS-89: Displaying of incorrect error message fixed for expressions with result shown right after definition;
  • SS-126: Fixed inserted snippet layout when collapsed Area Region exists inside Snippet;
  • SS-133: Description text updated for overridden definitions;
  • SS-141: Critical error on Shift+Right Arrow at the end of the TextRegion;
  • SS-143: Freezing of the application fixed on some copy/paste operations;
  • SS-151: Printing: layout fixed when Page Setup is non-standard;
  • SS-156: Fixed zoom in reference books;
  • SS-160: Wrong results with optimization None fixed;
  • SS-171: Collapsed Area related issues are fixed;
  • SS-173: Wrong display of units with subtext if comma is set as decimal separator;
  • Functions palette updated to insert diff() function with two arguments;
  • Long time Plot calculation fixed when equation for Plot contains empty placeholders;
  • Teamwork Session feature disabled (temporarily);
  • Crashing on application start fixed in case of incorrect response from server on check for update operation;
  • Simplification error fixed (incorrect sign of the operand appeared sometimes for complex expressions);
  • Fixed removing of Regions based on RegionHolder when placeholder is empty;
  • Fixed issue when useless brackets appeared between operands;
  • Fixed issues appears on Custom Regions context menu actions usages (evaluation miss and others);
  • Incorrect MDI icon fixed on page creation;
  • Viewer fixed to support empty Title and/or Description of worksheet (using worksheet properties);
  • Fixed issues with Area collapse/expand operations;
  • Stability improved;
  • Language files updated;
  • Refactoring and optimizations.
System requirements
  • Desktop (Windows):
    Framework: .NET Framework 2.0
  • Desktop (Linux):
Interface languages (37 languages)
  • [ARA] Arabic / العربي
  • [BUL] Bulgarian / Български
  • [CAT] Catalan / Català
  • [CZE] Czech / Čeština
  • [DAN] Danish / Dansk
  • [DUT] Dutch / Nederlands
  • [ENG] English / English
  • [FAS] Persian / فارسی
  • [FIN] Finnish / Suomi
  • [FRE] French / Français
  • [GER] German / Deutsch
  • [GRE] Greek / Ελληνικά
  • [HEB] Hebrew / עברית
  • [HUN] Hungarian / Magyar
  • [ITA] Italian / Italiano
  • [JPN] Japanese / 日本語
  • [KOR] Korean / 한국어
  • [LAV] Latvian / Latviešu
  • [LTH] Lithuanian / Lietuvių
  • [NOR] Norwegian / Norsk
  • [POL] Polish / Polski
  • [RON] Romanian / Română
  • [RUS] Russian / Русский
  • [SCR] Croatian / Hrvatski
  • [SLK] Slovak / Slovenčina
  • [SPA] Spanish / Español
  • [SWE] Swedish / Svenska
  • [TUR] Turkish / Türkçe
  • [UKR] Ukrainian / Українська
Free Download
Tutorial
Other files
7位用户喜欢此帖子
ioan92 2014/8/4 13:26:00, Martin Kraska 2014/8/4 18:39:00, sergio 2014/8/4 14:40:00, IVR 2014/8/4 15:15:00, Вячеслав Мезенцев 2014/8/4 15:55:00, Radovan Omorjan 2014/8/4 16:00:00, Davide Carpi 2014/8/4 17:50:00
#2 已发布: 2014/8/4 18:39:24
1,362个赞,共2,276个帖子。
Radovan Omorjan 2014/8/5 03:39:00
#3 已发布: 2014/8/5 11:47:08
w4cek
w4cek
1个赞,共1个帖子。
Hi! I have problem after updating to the lastest version from previous one. After opening sm file, which contains combobox region, program crashes. I'm the only one to experience this problem?
Davide Carpi 2014/8/7 10:39:00
#4 已发布: 2014/8/5 12:34:37
600个赞,共1,381个帖子。
no you are not. the very same calculation sheet with comboboxlist does not, but the old combobox makes it crash.
#5 已发布: 2014/8/5 15:01:31
1,443个赞,共2,936个帖子。
Hi Ioan, thanks for the complete debug (I can replicate it)
In the end this is the source:
			using (this.RegionPreview.Parent.History.CreateTransaction())
				this.RegionPreview.RequestForEvaluation();
and cause this error:
System.MissingMethodException: Méthode introuvable : 'Transaction SMath.Control.HistoryManager.CreateTransaction(Boolean, Boolean)'.
I've updated my sources with new APIs but I've not noticed errors compiling the plugin.
2位用户喜欢此帖子
ioan92 2014/8/5 15:25:00, Andrey Ivashov 2014/8/5 15:57:00
#6 已发布: 2014/8/5 16:11:33
2,344个赞,共4,057个帖子。
Hello.
Seems your really need just to rebuild (recompile) your plug-in (with version number changing). The thing is that improvements done for Areas support made it possible to remove second optional argument of CreateTransaction function and looking at the error you show this might be a reason. To say truth I didn't know that this change can result in any problems.
Davide Carpi 2014/8/5 18:03:00
#7 已发布: 2014/8/5 18:11:13
1,443个赞,共2,936个帖子。
Thank you Andrey you're right (obviously), the recompiled plugin works fine.
EDIT I've made a massive update of control regions.
#8 已发布: 2014/8/5 19:04:36
1,443个赞,共2,936个帖子。
RadioButtons pluging must follow the same treatement.
I've updated any control a little bit before you post this message, check the gallery
The syndrome of recalculating the page after each line introduction is no more active with the new version, but it is transfered now on the event click on ComboBoxList or RadioButton.
I don't understand, what do you think is wrong?
P.S. as for now seems that I can't no more trigger evaluations with using(CreateTransaction()) therefore some preview functions of various regions may need to close the settings form to see them.
#9 已发布: 2014/8/6 01:47:14
1,362个赞,共2,276个帖子。
I did not experience any problem with control regions. Thus I did not do the plugin update so far and wonder if I should do.
SMath Studio: SMath Studio Desktop 0.97.5329.37654, x64
OS: Microsoft Windows NT 6.1.7601 Service Pack 1 (Microsoft Windows 7 Professional , x64)
Screen: 1920x1080 px, 96x96 dpi
Localization: separator=; decimal symbol=; system decimal symbol=; language=GER
Frameworks: CLR 2.0.50727.5477
installed versions:
v2.0.50727 2.0.50727.5420 SP2
v3.0 3.0.30729.5420 SP2
v3.5 3.5.30729.5420 SP1
v4
Client 4.5.50709
Full 4.5.50709
v4.0
Client 4.0.0.0
#10 已发布: 2014/8/6 04:44:58
127个赞,共342个帖子。
I also like Martin I had no problems right now and I don't know if it is useful to update the plugins.
Smath 0.97 build 5329
Win7 64bit
#11 已发布: 2014/8/6 04:52:05
1,443个赞,共2,936个帖子。
This is the simplest way to replicate the bug:
Simply, by clicking a comboboxlist, the program crashes.
ioan92 2014/8/6 05:03:00
#12 已发布: 2014/8/6 05:52:32
1,443个赞,共2,936个帖子。
after each click on a control, the whole sheet is recalculated, aspect practically very annoying.
I confirmed this on two different computers (Windows 8.1).
Ok, seen... I can confirm that a double evaluation is triggered when the control changes the output value (at least in ComboBoxList, not in RadioButtonsList). I'll investigate if this is a bug from SMath or maybe a bug in the plugin due to some workaround to solve bugs in previous APIs...
edit there's a fuzzy logic behind this behavior... I've made a simple worksheet with the two regions and sometimes ComboBoxList triggers the double evaluation, sometimes this is done by RadioButtonsList and sometimes all goes right...
edit 2 seems that the issues begins from SMath 0.97.5327 (see here for a summary of the issues)
ioan92 2014/8/6 05:56:00
#13 已发布: 2014/8/7 14:00:17
1,362个赞,共2,276个帖子。
Portable distribution updated. Now with current SMath version and updated interactive handbook.
ioan92 2014/8/8 13:20:00
#14 已发布: 2014/8/15 17:28:07
asmathuser
asmathuser
0个赞,共2个帖子。
First of all, thanks Andrey for developing this great app and thanks everyone who added more functions to it with further developments!
I have upgraded to the newest version recently and had been experiencing problem with a file that was fine before. It happened when I scrolled to the right of the file where there are some images pasted in the region. The program would crash, the Window with the error message would pop up and the scroll region would show only red "X". I could click continue and pull down the new split region to keep working on the file, but if I scrolled right again, same thing would happen to that region and then I had to close the file, because both regions are now just filled with a red "X". Sometimes it would work when I scroll right, but then it would crash when I scrolled down.
Here is the error detail:
Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately.
Stack empty.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.InvalidOperationException: Stack empty.
at System.ThrowHelper.ThrowInvalidOperationException(ExceptionResource resource)
at System.Collections.Generic.Stack`1.Peek()
at SMath.Control.HistoryManager.(RegionBase )
at SMath.Control.RegionBase.(Point )
at SMath.Control.AreaRegion.set_Location(Point value)
at SMath.Control.WorksheetControl.(RegionBase , Int32 )
at SMath.Control.WorksheetControl.OnPaint(PaintEventArgs e)
at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
at System.Windows.Forms.Control.WmPaint(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
SMathStudio_Desktop
Assembly Version: 0.97.5329.37726
Win32 Version: 1.1.27.0
CodeBase: file:///C:/Program%20Files%20(x86)/SMath/SMath%20Studio/SMathStudio_Desktop.exe
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 2.0.50727.5467 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
ioman
Assembly Version: 0.97.5329.37654
Win32 Version: 0.97.5329.37654
CodeBase: file:///C:/Program%20Files%20(x86)/SMath/SMath%20Studio/ioman.DLL
canvas
Assembly Version: 0.97.5329.37656
Win32 Version: 0.97.5329.37656
CodeBase: file:///C:/Program%20Files%20(x86)/SMath/SMath%20Studio/canvas.DLL
rview
Assembly Version: 0.97.5329.37725
Win32 Version: 0.97.5329.37725
CodeBase: file:///C:/Program%20Files%20(x86)/SMath/SMath%20Studio/rview.DLL
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
CustomFunctions
Assembly Version: 1.0.5287.18879
Win32 Version: 1.0.5287.18879
CodeBase: file:///C:/Users/xxx/AppData/Roaming/SMath/extensions/plugins/18dadffd-79a3-4cf9-aee1-d66deb0ea720/1.0.5287.18879/CustomFunctions.dll
3DPlotRegion
Assembly Version: 0.1.5161.27307
Win32 Version: 0.1.5161.27307
CodeBase: file:///C:/Users/xxx/AppData/Roaming/SMath/extensions/plugins/2427d808-1e5e-4ae0-88bf-bc271664a3ab/0.1.5161.27307/3DPlotRegion.dll
NuLib
Assembly Version: 1.64.5329.37656
Win32 Version: 1.64.5329.37656
CodeBase: file:///C:/Program%20Files%20(x86)/SMath/SMath%20Studio/NuLib.DLL
System.Design
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll
FunctionsExtension
Assembly Version: 0.0.5261.2193
Win32 Version: 0.0.5261.2193
CodeBase: file:///C:/Users/xxx/AppData/Roaming/SMath/extensions/plugins/24c691c1-37f2-49e3-9a84-ccb77304d14a/0.0.5261.2193/FunctionsExtension.dll
DotNumerics
Assembly Version: 1.1.4972.7520
Win32 Version: 1.1.4972.7520
CodeBase: file:///C:/Users/xxx/AppData/Roaming/SMath/extensions/plugins/2a69099d-3185-4ea7-a130-65f2bf94c8d6/1.1.4972.7520/DotNumerics.dll
HyperlinkRegion
Assembly Version: 1.0.5333.34739
Win32 Version: 1.0.5333.34739
CodeBase: file:///C:/Users/xxx/AppData/Roaming/SMath/extensions/plugins/4938d1a8-ad11-4de8-afbf-d76d069cfbf8/1.0.5333.34739/HyperlinkRegion.dll
TableRegion
Assembly Version: 0.1.5190.1398
Win32 Version: 0.1.5190.1398
CodeBase: file:///C:/Users/xxx/AppData/Roaming/SMath/extensions/plugins/51fec712-ec75-4551-a13e-478d375ae8d6/0.1.5190.1398/TableRegion.dll
DataExchange
Assembly Version: 1.0.5172.2758
Win32 Version: 1.0.5172.2758
CodeBase: file:///C:/Users/xxx/AppData/Roaming/SMath/extensions/plugins/5dce7298-9e5f-4120-9a2e-49b16daa02a3/1.0.5172.2758/DataExchange.dll
Ionic.Zip
Assembly Version: 1.9.1.8
Win32 Version: 1.9.1.8
CodeBase: file:///C:/Users/xxx/AppData/Roaming/SMath/extensions/plugins/5dce7298-9e5f-4120-9a2e-49b16daa02a3/1.0.5172.2758/Ionic.Zip.dll
ClosedXML
Assembly Version: 0.68.1.0
Win32 Version: 0.68.1.0
CodeBase: file:///C:/Users/xxx/AppData/Roaming/SMath/extensions/plugins/621b8a62-bd79-47fc-948b-d4c4ab3b8588/1.0.4909.14933/ClosedXML.dll
DocumentFormat.OpenXml
Assembly Version: 2.0.5022.0
Win32 Version: 2.0.5022.0
CodeBase: file:///C:/Users/xxx/AppData/Roaming/SMath/extensions/plugins/621b8a62-bd79-47fc-948b-d4c4ab3b8588/1.0.4909.14933/DocumentFormat.OpenXml.DLL
System.Core
Assembly Version: 3.5.0.0
Win32 Version: 3.5.30729.5420 built by: Win7SP1
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
WindowsBase
Assembly Version: 3.0.0.0
Win32 Version: 3.0.6920.5453 built by: Win7SP1GDR
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll
XlsxImportExport
Assembly Version: 1.0.4909.14933
Win32 Version: 1.0.4909.14933
CodeBase: file:///C:/Users/xxx/AppData/Roaming/SMath/extensions/plugins/621b8a62-bd79-47fc-948b-d4c4ab3b8588/1.0.4909.14933/XlsxImportExport.dll
ImageRegion
Assembly Version: 1.97.5327.41206
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Users/xxx/AppData/Roaming/SMath/extensions/plugins/63ddaef8-9a56-4ff6-938e-d590b638bf99/1.97.5327.41206/ImageRegion.dll
SharpVectors.Core
Assembly Version: 0.3.1.1588
Win32 Version: 0.3.1.1588
CodeBase: file:///C:/Users/xxx/AppData/Roaming/SMath/extensions/plugins/63ddaef8-9a56-4ff6-938e-d590b638bf99/1.97.5327.41206/SharpVectors.Core.dll
SharpVectors.Css
Assembly Version: 0.3.1.1590
Win32 Version: 0.3.1.1590
CodeBase: file:///C:/Users/xxx/AppData/Roaming/SMath/extensions/plugins/63ddaef8-9a56-4ff6-938e-d590b638bf99/1.97.5327.41206/SharpVectors.Css.dll
SharpVectors.Dom
Assembly Version: 0.3.1.1589
Win32 Version: 0.3.1.1589
CodeBase: file:///C:/Users/xxx/AppData/Roaming/SMath/extensions/plugins/63ddaef8-9a56-4ff6-938e-d590b638bf99/1.97.5327.41206/SharpVectors.Dom.DLL
SharpVectors.Model
Assembly Version: 0.3.1.1592
Win32 Version: 0.3.1.1592
CodeBase: file:///C:/Users/xxx/AppData/Roaming/SMath/extensions/plugins/63ddaef8-9a56-4ff6-938e-d590b638bf99/1.97.5327.41206/SharpVectors.Model.dll
SharpVectors.Rendering.Gdi
Assembly Version: 0.3.1.1595
Win32 Version: 0.3.1.1595
CodeBase: file:///C:/Users/xxx/AppData/Roaming/SMath/extensions/plugins/63ddaef8-9a56-4ff6-938e-d590b638bf99/1.97.5327.41206/SharpVectors.Rendering.Gdi.dll
ExcelFileType
Assembly Version: 1.3.5293.42559
Win32 Version: 1.3.5293.42559
CodeBase: file:///C:/Users/xxx/AppData/Roaming/SMath/extensions/plugins/7b0c4cfe-fe73-47f1-a4f8-6b3ebcd094e8/1.3.5293.42559/ExcelFileType.dll
ICSharpCode.SharpZipLib
Assembly Version: 0.86.0.518
Win32 Version: 0.86.0.518
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/ICSharpCode.SharpZipLib/0.86.0.518__1b03e6acf1164f73/ICSharpCode.SharpZipLib.dll
NPOI
Assembly Version: 2.0.1.0
Win32 Version: 2.0.1.0
CodeBase: file:///C:/Users/xxx/AppData/Roaming/SMath/extensions/plugins/7b0c4cfe-fe73-47f1-a4f8-6b3ebcd094e8/1.3.5293.42559/NPOI.dll
NPOI.OOXML
CodeBase: file:///C:/Users/xxx/AppData/Roaming/SMath/extensions/plugins/7b0c4cfe-fe73-47f1-a4f8-6b3ebcd094e8/1.3.5293.42559/NPOI.OOXML.dll
NPOI.OpenXmlFormats
CodeBase: file:///C:/Users/xxx/AppData/Roaming/SMath/extensions/plugins/7b0c4cfe-fe73-47f1-a4f8-6b3ebcd094e8/1.3.5293.42559/NPOI.OpenXmlFormats.DLL
NPOI.OpenXml4Net
CodeBase: file:///C:/Users/xxx/AppData/Roaming/SMath/extensions/plugins/7b0c4cfe-fe73-47f1-a4f8-6b3ebcd094e8/1.3.5293.42559/NPOI.OpenXml4Net.dll
CFLabelRegion
Assembly Version: 1.0.5321.21080
Win32 Version: 1.0.5321.21080
CodeBase: file:///C:/Users/xxx/AppData/Roaming/SMath/extensions/plugins/a43ac8f9-29d7-4e8a-9ad0-82cf7c4e14f6/1.0.5321.21080/CFLabelRegion.dll
HTMLFileType
Assembly Version: 1.13.5329.37657
Win32 Version: 1.13.5329.37657
CodeBase: file:///C:/Program%20Files%20(x86)/SMath/SMath%20Studio/plugins/HTMLFileType.dll
ImageFileType
Assembly Version: 1.9.5329.37663
Win32 Version: 1.9.5329.37663
CodeBase: file:///C:/Program%20Files%20(x86)/SMath/SMath%20Studio/plugins/ImageFileType.dll
PictureRegion
Assembly Version: 1.10.5329.37670
Win32 Version: 1.10.5329.37670
CodeBase: file:///C:/Program%20Files%20(x86)/SMath/SMath%20Studio/plugins/PictureRegion.dll
PlotRegion
Assembly Version: 1.9.5329.37676
Win32 Version: 1.9.5329.37676
CodeBase: file:///C:/Program%20Files%20(x86)/SMath/SMath%20Studio/plugins/PlotRegion.dll
SMathFileType
Assembly Version: 1.9.5329.37682
Win32 Version: 1.9.5329.37682
CodeBase: file:///C:/Program%20Files%20(x86)/SMath/SMath%20Studio/plugins/SMathFileType.dll
SpecialFunctions
Assembly Version: 1.11.5329.37689
Win32 Version: 1.11.5329.37689
CodeBase: file:///C:/Program%20Files%20(x86)/SMath/SMath%20Studio/plugins/SpecialFunctions.dll
TextRegion
Assembly Version: 1.10.5329.37695
Win32 Version: 1.10.5329.37695
CodeBase: file:///C:/Program%20Files%20(x86)/SMath/SMath%20Studio/plugins/TextRegion.dll
ViewerFileType
Assembly Version: 1.1.5329.37703
Win32 Version: 1.1.5329.37703
CodeBase: file:///C:/Program%20Files%20(x86)/SMath/SMath%20Studio/plugins/ViewerFileType.dll
XMCDFileType
Assembly Version: 1.12.5329.37709
Win32 Version: 1.12.5329.37709
CodeBase: file:///C:/Program%20Files%20(x86)/SMath/SMath%20Studio/plugins/XMCDFileType.dll
SyLib
Assembly Version: 1.31.5329.37655
Win32 Version: 1.31.5329.37655
CodeBase: file:///C:/Program%20Files%20(x86)/SMath/SMath%20Studio/SyLib.DLL
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
ltx4t1b_
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
I am wondering if anyone has experienced that, I have updated all plug-ins, thanks.
#15 已发布: 2014/8/16 03:22:39
1,362个赞,共2,276个帖子。
This is a known bug. Andrey marked it as fixed (thus you normally won't see it in the bug tracking system) but there is no corresponding maintenance release so far.
#16 已发布: 2014/8/18 19:09:02
asmathuser
asmathuser
0个赞,共2个帖子。
Thanks for your reply Martin! I will await patiently for next update, for now, I have rolled back to carry on.
