1页(7条)
Arch Linux doesn't display greek characters on button in the left side - 消息
It doesn't show me greek characters in right side buttons, it show some rectangles. In worksheet greek characters works.
Same here for a very long time. I have installed several font packs but couldn't succeed.
To be honest, somehow I did used to this issue. Yet sometimes I click several buttons to find correct letter
Please try this build: http://smath.info/file/yaoVu - if Greek chars will be shown ok I will include the fix into the next stable version of SMath Studio.
Thank you in advance!
WrotePlease try this build: http://smath.info/file/yaoVu - if Greek chars will be shown ok I will include the fix into the next stable version of SMath Studio.
Nope, this build doens't start on my system, I think that I miss some font but I don't know which, the version you link me abort with this error:
Unhandled Exception:
System.Exception: Can't find a proper language file. Try to reinstall the program.
at SMath.Manager.SessionsManager.ReloadLanguages () [0x00060] in <cc3205659b864dac8764824a4bc9a689>:0
at SMath.UI.SessionsManagerPaths.Create (System.String[] paths) [0x0001d] in <25490bd212e14fd0a47fd12bfc12ca47>:0
at SMath.UI.AppSettingsDesktop.Initialize (SMath.Manager.PluginsStatusEventHandler loaded) [0x0005e] in <25490bd212e14fd0a47fd12bfc12ca47>:0
at SMath.UI.Desktop.Program. (System.String[] ) [0x0005b] in <a5ff19d5461b4be49f91c8081ba62fc2>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.Exception: Can't find a proper language file. Try to reinstall the program.
EDIT: I see that I have the same error with beta version 0.99.6824, only the stable version 0.99.6671 and older work for me
Thank you! Yeah, this was an error in latest beta. Just fixed it.
I think now everything should work as expected, please test: http://smath.info/file/TR8Ne (I've tested it successfully on Ubuntu 18.04.1)
Best regards, Andrey Ivashov.
overlord 2018/9/15 05:52:00
WroteThank you! Yeah, this was an error in latest beta. Just fixed it.
Ok this version solved the greek issue but there is a new problem, on startup it say me to update some plugins (I think because new version need new plugins version) but if I click on update the program crash with this error:
System.InvalidOperationException: Collection was modified; enumeration operation may not execute.
at System.Collections.ArrayList+ArrayListEnumeratorSimple.MoveNext () [0x00013] in <815942dd495d4ccc954b977c1d4bee11>:0
at System.Windows.Forms.Hwnd.AddInvalidArea (System.Drawing.Rectangle rect) [0x00037] in <206d6d7865674caba761ab5f5b301dc0>:0
at System.Windows.Forms.Hwnd.AddInvalidArea (System.Int32 x, System.Int32 y, System.Int32 width, System.Int32 height) [0x0000b] in <206d6d7865674caba761ab5f5b301dc0>:0
at System.Windows.Forms.XplatUIX11.AddExpose (System.Windows.Forms.Hwnd hwnd, System.Boolean client, System.Int32 x, System.Int32 y, System.Int32 width, System.Int32 height) [0x00057] in <206d6d7865674caba761ab5f5b301dc0>:0
at System.Windows.Forms.XplatUIX11.UpdateMessageQueue (System.Windows.Forms.XEventQueue queue, System.Boolean allowIdle) [0x002ec] in <206d6d7865674caba761ab5f5b301dc0>:0
at System.Windows.Forms.XplatUIX11.UpdateMessageQueue (System.Windows.Forms.XEventQueue queue) [0x00000] in <206d6d7865674caba761ab5f5b301dc0>:0
at System.Windows.Forms.XplatUIX11.GetMessage (System.Object queue_id, System.Windows.Forms.MSG& msg, System.IntPtr handle, System.Int32 wFilterMin, System.Int32 wFilterMax) [0x0001c] in <206d6d7865674caba761ab5f5b301dc0>:0
at System.Windows.Forms.XplatUI.GetMessage (System.Object queue_id, System.Windows.Forms.MSG& msg, System.IntPtr hWnd, System.Int32 wFilterMin, System.Int32 wFilterMax) [0x00000] in <206d6d7865674caba761ab5f5b301dc0>:0
at System.Windows.Forms.Application.RunLoop (System.Boolean Modal, System.Windows.Forms.ApplicationContext context) [0x0034e] in <206d6d7865674caba761ab5f5b301dc0>:0
at System.Windows.Forms.Application.Run (System.Windows.Forms.ApplicationContext context) [0x00011] in <206d6d7865674caba761ab5f5b301dc0>:0
at System.Windows.Forms.Application.Run (System.Windows.Forms.Form mainForm) [0x00006] in <206d6d7865674caba761ab5f5b301dc0>:0
at .. () [0x0000a] in <7855f2562e4d4c67b6d2fafcf667b6ab>:0
at System.Threading.ThreadHelper.ThreadStart_Context (System.Object state) [0x00014] in <815942dd495d4ccc954b977c1d4bee11>:0
at System.Threading.ExecutionContext.RunInternal (System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, System.Object state, System.Boolean preserveSyncCtx) [0x00071] in <815942dd495d4ccc954b977c1d4bee11>:0
at System.Threading.ExecutionContext.Run (System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, System.Object state, System.Boolean preserveSyncCtx) [0x00000] in <815942dd495d4ccc954b977c1d4bee11>:0
at System.Threading.ExecutionContext.Run (System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, System.Object state) [0x0002b] in <815942dd495d4ccc954b977c1d4bee11>:0
at System.Threading.ThreadHelper.ThreadStart () [0x00008] in <815942dd495d4ccc954b977c1d4bee11>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.InvalidOperationException: Collection was modified; enumeration operation may not execute.
Andrey Ivashov 2018/9/14 16:31:00
well, this version just works for me. no greek letters issue except the title of alphabet panels, no error for plugins.
good job, thanks for your quick action.
regards
1页(7条)
