1页(7条)
Error of a function with Summation - The output of a function with summation has error - 消息
Hi!
I'm a novice for SMath.
I'm porting a Mathcad 15 file to SMath.
I found that the SMath function with Summation has some error.
There are difference between the output of direct calculation and function output.(See attached pictures)
Please, check it and help me.
Best regards,
Novice
未找到文件。未找到文件。未找到文件。
Best regards,
Novice
未找到文件。未找到文件。未找到文件。
Looks like a bug. If you right click DD(0), and change the optimization to symbolic, it gives the right answer.
MSL 2016/5/18 01:32:00
WroteLooks like a bug. If you right click DD(0), and change the optimization to symbolic, it gives the right answer.
Thank you!
Whenever I got'the error message, "Result is above max. allowed positive number", I'll try to change the option.
1页(7条)
