element-wise matrix operations
element-wise matrix operations - 消息
#1 已发布: 2010/10/21 21:20:56
iveyj1
iveyj1
0个赞,共2个帖子。
Folks,
Is there a way to cause matrix operations to be performed
element by element? For example if two matrices are
multiplied, the top-left element of the multiplicand
would be multiplied by the top-left element of the multiplier
and placed in the top-left element of the product, and
so on. In mathcad this can be done by pressing -
(vectorize).
Thanks,
Jack
#2 已发布: 2010/10/22 02:00:06
325个赞和1个踩,共2,052个帖子。
No, there is no element-wise matrix operations in Smath (like vectorize in Mathcad). You just have to use loops (for, while) to perform such operations.
#3 已发布: 2010/10/22 21:19:06
iveyj1
iveyj1
0个赞,共2个帖子。
Ok, thanks for the quick response.
Is it possible to add operators via the plugin
mechanism or would that require a change to the core?
The reason I am interested in this functionality
is that I use it heavily in Mathcad to perform
similar calculations on a set of variables. The for
loop provides a similar functionality, but
the visual presentation is much more awkward,
unless I am missing something.
By the way, this is one of the best and most needed free
software I have come across.
Thanks,
Jack
#4 已发布: 2025/9/22 09:11:58
Gerhard
Gerhard
0个赞,共1个帖子。
Haha, 15 years later, I'm facing the same problem. For my calculation of screw forces, I need the square distances of my screws and thought I could calculate them element by element.
Then I'll have to try to write a for loop.
#5 已发布: 2025/9/22 09:51:35
federico
federico
6个赞,共8个帖子。
"Vectorize" is available and, if I understood your request, it should work for your use case without need of any loop.
