[SS-13] Matrix Insert Row or Column
[SS-13] Matrix Insert Row or Column - Some data sets that were transcribed are missing insormation - 消息
#1 已发布: 2018/4/12 14:10:56
Ruben Sidranski
Ruben Sidranski
17个赞,共465个帖子。
Adding a row or column in Mathcad, mid Matrix, was simple. In SMath, I cannot copy portions of the matrix to move the information (all or nothing) as I've tri. Am I missing anything?
Matrix -Insert Row or Column.sm (5.2 KiB)已下载 1690 次。
#2 已发布: 2018/4/12 14:19:30
1,443个赞,共2,936个帖子。
Cutrrently not possible: [SS-13]
#3 已发布: 2018/4/12 14:23:48
Ruben Sidranski
Ruben Sidranski
17个赞,共465个帖子。
Thank you Just added a vote to this item
#4 已发布: 2018/4/12 15:42:29
983个赞,共6,866个帖子。
Easy/simple ... it's ADD not INSERT
Matrix -Insert Row or Column.sm (12.53 KiB)已下载 1775 次。
#5 已发布: 2018/4/12 20:35:51
983个赞,共6,866个帖子。
In SMath, I cannot copy portions of the matrix to move the information (all or nothing) ...
Simply => submatrix !
#6 已发布: 2018/4/12 20:37:35
983个赞,共6,866个帖子。
simply submatrix !
#7 已发布: 2018/4/13 03:26:21
Martin_B
Martin_B
22个赞,共84个帖子。
You can use this tool. It also allows conversion between Excel and Smath.
Smath Tools:
https://smath.info/wiki/Tools.ashx
#8 已发布: 2018/4/13 09:04:16
983个赞,共6,866个帖子。
Dead like stone, better use Smath tool ! page 14
Utilities Matrix Treasury_0 Copy.sm (496.62 KiB)已下载 1747 次。
#9 已发布: 2018/4/16 17:24:55
Ruben Sidranski
Ruben Sidranski
17个赞,共465个帖子。
Jean,
Sometimes your convoluted solutions really do inspire ... when I understand them
Here is a work around that works for me. I did NOT try it as an insert to column or row index 1 as I assume these exist. If those are needed, I guess we use augment. At the end of a matrix, we can just pull the handle. RS_Insert cols_rows to Matrices.smz (6.87 KiB)已下载 1821 次。
Thank you
#10 已发布: 2018/4/16 21:08:50
983个赞,共6,866个帖子。
Pad(M,nc,nr) ... padding a matrix has the meaning centered [nc,nr] insertion,
reserved for Fourier 'ifft'... why did you remove it.
For common work, rater use InsertCol/InsertRow.
RS_Insert cols_rows to Matrices(1).sm (47.58 KiB)已下载 1776 次。
