1页(7条)
Adding Margins to worksheets - Adding margins - 消息
Is there a way of adding Margins to a Worksheet ?
I'd like to put a vertical line down the RH side of the page approx 25mm from the edge
Thanks
Thanks
Peter J Francis
Twitter: @PeterJFrancis
Thermal Engineer , Maker , Pilot
For margins: Menu -> File -> Page Setup
For the vertical line: Menu -> Insert -> background -> background image and insert a background file prepared with your favorite decorations
2位用户喜欢此帖子
Thanks you , I didn't realise that was possible !
All the best
Peter
All the best
Peter
Peter J Francis
WroteI'd like to put a vertical line down the RH side of the page approx 25mm from the edge
You can have more than just a line.
If you have the message "can't find file ... just ignore.
This is because Smath stores the two regions internally
and can't retrieve because incomplete [no argument] regions.
Page13 Margin.sm (3.3 KiB)已下载 1434 次。
Thanks for the reply Jean,
your suggestion re 'adjustable length/width' looks exactly what I want but
I'm not familiar with image regions so I don't really understand how to impliment it
Do you have an example I could look at ?
Thanks
Thanks
Peter J Francis
... like this Peter, now slide wherever in the work sheet.
Template Margin Line RGBYCM.sm (34.78 KiB)已下载 1242 次。
1页(7条)
