lookup fuction
lookup fuction - 消息
#1 已发布: 2023/3/6 05:02:40
soomoon
soomoon
1个赞,共42个帖子。
I would like to have a function like lookup (vlookup, hlookup) in smath.
thank you.
未找到文件。未找到文件。
João Felipe Seráfico Melo 2023/3/6 10:09:00
#2 已发布: 2023/3/6 05:45:04
7个赞,共62个帖子。
findrows function within Special Functions plugin is what you're looking for, soomoon
#3 已发布: 2023/3/6 08:36:22
983个赞,共6,866个帖子。
Find Index Key Code is lot more powerful.
Assume your Customer wants more information from his bar diameter
you can give all pertaining informations ...
Add price column, material, delivery ... etc.
bar size Findndex KeyCode.sm (10.33 KiB)已下载 1320 次。
#4 已发布: 2023/3/6 09:14:07
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
bar size.sm (9.63 KiB)已下载 1329 次。
João Felipe Seráfico Melo 2023/3/6 10:05:00
#5 已发布: 2023/3/6 10:05:04
7个赞,共62个帖子。
Jean, your example shows EXACTLY what findrows does.
#6 已发布: 2023/3/6 17:23:05
983个赞,共6,866个帖子。
Yes for that simple application.
FindIdx(V,x,col) gives me more for advanced Engineering works
Thanks for the observation.
#7 已发布: 2023/3/6 23:46:16
600个赞,共1,381个帖子。
https://en.smath.com/forum/yaf_postst673_lookup.aspx
Check thread above. You may find it useful.
You can look forum for your questions by searching too.
Searching may result with a ready answer to a question.
#8 已发布: 2023/3/7 12:30:02
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
findrows() function revisited.
As a part of a project undertaken to study flows of some perennial streams in Sri Lanka,
a particular stream, located far away from Colombo, was selected and a Rating Table (RT) was
prepared relating water levels to flows. This process took a few years so that the
data would almost cover reasonable range of depths for practical reasons, excluding severe floods.
During this period, an electronic device was also constructed to measure water levels (WL) and
transmit as digital signals to control station in Colombo.
However, the numerical values of transmitted WL had more than 6 decimals,
whereas the Rating Table (RT) was calibrated only to 2 decimals. Hence, initially WL values
had to be refined to 2 decimals for use with RT values.
Earlier a vlookup function which was posted in the forum was used, but it took a long time to process
But when the findrows function was available, data processing was dramatically fast.
Both Excel and SM files must be in the same folder.
Cheers
1.July WL&RT.xlsx (29.52 KiB)已下载 1005 次。
Find_Flows-R1.sm (26.11 KiB)已下载 1412 次。
Find_Flows-R1.pdf (234.55 KiB)已下载 982 次。
Mark R Harris 2023/3/8 16:34:00
