Vectors to solve individual equation
Vectors to solve individual equation - Not sure if bug or feature - 消息
#1 已发布: 2012/7/20 23:00:20
Ruben Sidranski
Ruben Sidranski
17个赞,共465个帖子。
OK, SO I have a basic question. How do I use a vector to solve an equation? See attached where I have Area defined and Diameter is 8 and 16 inches. As long as I don't square the equation, the result remains a vector
Vectors01.smz (2.68 KiB)已下载 1618 次。
#2 已发布: 2012/7/21 01:53:26
325个赞和1个踩,共2,052个帖子。
It seems that vectors - column matrix are multiplied getting their scalar product (sum of products of their elements). If you want the elemental product you should use for loop.
[MATH=eng]D:mat(8,16,2,1)[/MATH]
[MATH=eng]for(i,range(1,length(D)),el(A,i):π/4*el(D,i)^2)[/MATH]
[MATH=eng]A=mat(50.265,201.062,2,1)[/MATH]
ElSid 2012/7/25 10:35:00
#3 已发布: 2012/7/24 20:17:48
Ruben Sidranski
Ruben Sidranski
17个赞,共465个帖子。
Thanks. I figured it out slightly before you posted. I see this question has been previously asked ... as the equivalent of MathCADs vectorize (e.g. element-wise matrix operation) http://en.smath.info/forum/yaf_postsm3770findlastpost_element-wise-matrix-operations.aspx#post3770. I hope Andre can get this feature implemented for the same reason on the link.
Secondary question, when defining a NEW unit, is there a way of forcing it to show in the same font and color (blue) as the built in units?
#4 已发布: 2012/7/25 03:25:24
Steve Swinbanks
Steve Swinbanks
2个赞,共11个帖子。
Sure, just use the apostrophe "'" when defining the unit you want. Then from there it always displays the font and colour correctly.
Steve
2位用户喜欢此帖子
Radovan Omorjan 2012/7/25 07:37:00, ElSid 2012/7/25 10:35:00
