XY Plot Region
XY Plot Region - Problem Loading - 消息
#1 已发布: 2018/9/17 20:22:54
Dik
Dik
0个赞,共3个帖子。
When I try to load one of the files at:
https://en.smath.info/forum/yaf_postst1774_X-Y-Plot-Region.aspx
I get the message that XY Plot Region Plugin must be installed and I load it. I then get the message that the the file is already loaded. When I look at the list of installed plugins, XY Plot Region is not installed and I cannot find reference to a file for it on my entire computer, and no reference in the registry.
Does anyone have a suggestion on how to completely remove it so I don't get the message it is already installed or to make it 'visible' to SMath?
I've tried numerous approaches and have uninstalled and re-installed SMath 3 times now in an attempt to start with a 'clean' system.
All of the example files have unresolved references.
Dik
#2 已发布: 2018/9/17 20:36:46
1,558个赞,共1,868个帖子。
Install.
