at function in SMath
at function in SMath - 消息
#1 已发布: 2023/6/7 11:25:18
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
Hello!
What is the advantage of at function in SMath ?
Appreciate if any useful example is provided.
Cheers !
#2 已发布: 2023/6/7 12:34:30
1,139个赞,共1,805个帖子。
Hi Amarasekera, a pleasure to greet you. I'm sure others in this forum will be able to give very good examples, I would just like to add that the 'at' function is more or less similar to the 'eval' in maple, although it also has a 'subs' function, and even another one like 'algsubs', or Mathematica's f /. x -> a notation, and perhaps there you can see how those programs use it and get a better idea of what it might be useful for. I also remember that den derive, which did not have a function like at, could be used instead ... take the limit: lim f for x -> a
#3 已发布: 2023/6/7 14:01:37
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
Hi Amarasekera, a pleasure to greet you. I'm sure others in this forum will be able to give very good examples, I would just like to add that the 'at' function is more or less similar to the 'eval' in maple, although it also has a 'subs' function, and even another one like 'algsubs', or Mathematica's [b]f /. x -
Hi Alvaro, thank you very much for your kind sentiments and valuable clarifications.
#4 已发布: 2023/6/7 15:19:06
1,362个赞,共2,276个帖子。
Handbook page for at() and Solve(). at() is a convenient alternative for Assign(), which creates assignments based on equations (as returned by Solve, ODE2 or Fit())
at.sm (22.23 KiB)已下载 1390 次。
_Solve.sm (33.17 KiB)已下载 1417 次。
#5 已发布: 2023/6/7 16:48:46
983个赞,共6,866个帖子。
Some demo application.
Take care ... Jean.
Solve at(2), at(3).sm (30.21 KiB)已下载 1381 次。
#6 已发布: 2023/6/7 18:04:21
983个赞,共6,866个帖子。
Electron function added Φ(x,y)
This function has no symbolic solution.
It plots X_Y but for QuickPlot, you need solving.
Cheers ... Jean.
Solve at(2), at(3).sm (47.5 KiB)已下载 1425 次。
#7 已发布: 2023/6/7 23:33:01
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
Thank you all for the clarifications and examples
