1页(6条)
Frame and Beam analysis with Moment distribution method - Problem with Array - 消息
I have been trying to convert this Smath Studio file to Mathcad
and I have gone this far but found an error that said
"This Array index is invalid for this array."
Please comment on it.
Thanks.未找到文件。未找到文件。
Thanks.未找到文件。未找到文件。
WroteI have been trying to convert this Smath Studio file to Mathcad
Mathcad index starts 0 ... Smath 1
Your Smath document turns red Syntax is incorrect.
To be doctored ... so immense !
Wrotehave been trying to convert this Smath Studio file to Mathcad
The SMath program you are referring was posted sometime back to the FORUM by me.
It was based on the moment distribution method, and use of it is limited only to
cases of 2 span substitute frames.
Recently, I posted a couple of examples based on the stiffness method. which can
be used for any practical number of spans.
See the following link.
https://en.smath.com/forum/yaf_postsm80558_RC-Subframe-Analysis-by-Stiffness-Method.aspx#post80558
I have redone your example using this stiffness method, attaching it with a definition file.
These two files must be in the same folder please.
Unfortunately these two sm files are lengthy, and I sincerely welcome forum members
to propose any improvements..
I am extremely sorry that I am unable to check your example Mathcad file.
Cheers,
Include_Programs-R10.sm (118.66 KiB)已下载 1337 次。
MacGinley and Choo_Ex_13.1_TO_FORUM-STIFFNESS Method.sm (387.81 KiB)已下载 1462 次。
Davide Carpi 2023/2/23 10:06:00
Above example simplified to show only the Support and Column Moments.
Definition file not required.
Cheers
MacGinley and Choo_Ex_13.1_TO_FORUM-STIFFNESS Method-R1.sm (232.84 KiB)已下载 1500 次。
MacGinley and Choo_Ex_13.1_TO_FORUM-STIFFNESS Method-R1.pdf (333.69 KiB)已下载 910 次。
Cheers
The last example.
Cheers.
Reinforced-Concrete-Design-to-eurocode-2 Mosley Bungey Hulse-7th Ed-R10-Simple.sm (301.2 KiB)已下载 1520 次。
Reinforced-Concrete-Design-to-eurocode-2 Mosley Bungey Hulse-7th Ed-R10-Simple.pdf (435.46 KiB)已下载 3626 次。
Cheers.
Davide Carpi 2023/2/23 15:14:00
1页(6条)
