Fit Reverse Direction X
Fit Reverse Direction X - Fit Reverse Direction X - 消息
#1 已发布: 2022/9/21 11:15:40
983个赞,共6,866个帖子。
Data sets that exhibit reverse direction X are difficult to manage.
If noisy, you can attempt Ksmoothing providing they are well populated.
If too sparse, solution is via control point work shop.
This document offers 3 work shops: DeCasteljau, Hermite, DeBoor.
The three work shops have been fitted to comfort your lecture.
Once fitted/populated/parted, you can spline piecewise, as well Thiele.
For Thiele piecewise, you will have to de-populate the fit.
Inst_Fit Deasteljau Thiele.
Cheers ... Jean. Good visit.
Inst_Fit DeCasteljau Thiele.sm (21.97 KiB)已下载 1543 次。
Inst_Fit DeCasteljau Copy.sm (114.41 KiB)已下载 1528 次。
