1页(11条)
Roots - intersection points - Trouble with finding intersection points of a line and a parabola using "roots" command. - 消息
Good afternoon everyone.
I'm using the "roots" command, but I'm not getting the two points where the line intersects the parabola. The command gives me only one result and omits the other point. Attached is the file and image of the problem. How can I find both intersection points?
Roots.sm (8.44 KiB)已下载 1377 次。
WroteI'm using the "roots" command, but I'm not getting the two points where the line intersects the parabola. The command gives me only one result and omits the other point. Attached is the file and image of the problem. How can I find both intersection points?
As doctored ... Jean
Roots Doctored.sm (9.38 KiB)已下载 1402 次。
'roots' is essentially based on differentiable function.
Often, in Engineering works you don't have differentiable functions,
Gamma(x), spline fit ... etc.
In those cases, use the X(Φ,a,b,ε) utility.
Cheers ... Jean.
roots Gamma(x).sm (18.54 KiB)已下载 1383 次。
Cheers ... Jean.
PS: MapleCorrect() function can be found here.
Assign() function can be used instead of str2num() + num2str() + strrep().
My personal favourite way to handle solver results is Davide's at() substitution function.
![2023-04-16 01_39_35-SMath Solver - [Einheitenumrechnung.sm_].png](/zh-Hans-CN/files/Download/LmNhk6/2023-04-16-01_39_35-SMath-Solver---[Einheitenumrechnung.sm_].png)
Wrote'roots' is essentially based on differentiable function.
Many Smath built-in functions are not differentiable.
diff(▄ ▄) not defined ... Airy example attached.
roots Airy.sm (11.05 KiB)已下载 1357 次。
WroteHi. This is another way.
What the heck? Can we use maple keywords if they are written as `function`?
This is so mind-blowing, thanks Razonar.
Alvaro 2023/4/17 17:27:00
1页(11条)
