Graph animation - 消息
Title: Animation curve fitting using a hinged mechanism.
Author: Fridel Selitsky
Download: Lemniscate_mod.sm.
3位用户喜欢此帖子
Hello Andrey
Nice example of how to simulate an animation using rfile, wfile and F9.
Chebyshev’s Lambda MechanismLambda mechanism is another four-bar straight line generator. Crank link can rotate 360 degrees while the coupler point moves on coupler curve.
Curve has two characteristic motions. First part is straight line and second part is a quick return curve.
By pressing key F9 the top point of a connecting rod on some site describes a trajectory close to a straight line.
https://smath.com/wiki/GetFile.aspx?File=mechanizm2.rar
2位用户喜欢此帖子
Video event capture on the screen.
Teo Jansen walking mechanism
https://smath.com/wiki/GetFile.aspx?File=Walking.rar
Klann mechanism1
https://smath.com/wiki/GetFile.aspx?File=Klann.rar
Klann mechanism 2
https://smath.com/wiki/GetFile.aspx?File=Klann2noga.rar
Andrey Ivashov 2011/8/29 03:49:00
Russian Walking Machines "Vos'minog", developed by
and manufactured in VolgGTU (Volgograd).
Have a four-or six-walking mechanism.
1.four links
https://smath.com/wiki/GetFile.aspx?File=Vosminog.rar
1.four links
2.six links
https://smath.com/wiki/GetFile.aspx?File=Vosminog2.rar
The motion of the figure, consisting of circular arcs
https://smath.com/wiki/GetFile.aspx?File=Kruk.rar
Davide Carpi 2012/10/1 17:57:00
Cannabis Curve
https://smath.com/wiki/GetFile.aspx?File=Cannabis.rar
2位用户喜欢此帖子
Animations of Ber7 are amazing, no doubt
There should be a gallery of all these fantastic animations in one dedicated place.
Chrysanthemum curve
https://smath.com/wiki/GetFile.aspx?File=Chrysanthemum.rar
2位用户喜欢此帖子
Butterfly Curve
https://smath.com/wiki/GetFile.aspx?File=Butterfly.rar
Sierpinski triangle( Used the program of Uni)
https://smath.com/files/Download/k22b2
https://smath.com/wiki/GetFile.aspx?File=Serpinsky.rar
3位用户喜欢此帖子
Hi
I've run into this site of a GUI inventor? an thought Ber7 might be interested. It seems to me very inspiring.
http://worrydream.com/
For example, look at the 'kill math' section and the concepts about 'interactive exploration of a dynamical system'
Fridel Selitsky 2012/2/25 00:49:00
Bouncing ball
The algorithm is taken from here:
http://communities.ptc.com/message/188318#188318
https://smath.com/wiki/GetFile.aspx?File=Bounce.rar
Davide Carpi 2012/9/28 11:19:00
Whirls are figures constructed by nesting a sequence of polygons (each having the same number of sides), each slightly smaller and rotated relative to the previous one. The vertices form logarithmic spirals. The problem is taken from the site http://mathworld.wolfram.com/Whirl.html
Wolfram1.smz (3.74 KiB)已下载 1372 次。
3位用户喜欢此帖子
Andrey Ivashov 2012/12/28 13:58:00, Davide Carpi 2012/12/23 19:51:00, Martin Kraska 2012/12/23 20:31:00
