wfile function fractional output
wfile function fractional output - 消息
#1 已发布: 2019/4/4 04:00:47
koraykadas
koraykadas
0个赞,共2个帖子。
Hi Everybody,
I am trying to export (i.e., write to a text file) a vector of decimal numbers. With wfile function, I am only able to get fractional representation of data available. Is it possible to export numbers in decimal format only or should I convert them in Excel manually at the moment?
I will appreciate any other suggestion (other plugin or function) as an alternative.
#2 已发布: 2019/4/4 05:11:31
127个赞,共342个帖子。
You can use the "Data Exchange" plugin -> "ExportData.CSV" function
#3 已发布: 2019/4/4 05:46:04
koraykadas
koraykadas
0个赞,共2个帖子。
Solved. Many Thanks Sergio
#4 已发布: 2019/4/4 08:31:27
983个赞,共6,866个帖子。
If the data 'frac' is long enough, Ω will show truncated
enclose [Ω]= for full length ... [,] from matrix palette 1 row, 1 col.
