1页(9条)
Analog Clock - A simple animation - 消息
4位用户喜欢此帖子
ioan92 2013/7/9 11:21:00, Вячеслав Мезенцев 2013/7/11 13:12:00, Andrey Ivashov 2013/7/10 08:27:00, Fridel Selitsky 2013/7/9 14:27:00
Beautiful animation: To reduce the computation time can be operators "for", which do not depend on time, move out of the function cloc (s).
Best Regards,Ber7.
AnalogClock1.sm (22.29 KiB)已下载 1445 次。
Best Regards,Ber7.
2位用户喜欢此帖子
Thank you ber,
this make the script faster and easier to read
Best regards,
Davide
P.S. worksheet updated
Best regards,
Davide
Davide,if your program to change the settings a bit, we get
"real" analog clock (all the arrows are moving continuously).
Best Regards,
Ber7
AnalogClock2.sm (21.44 KiB)已下载 1516 次。
Best Regards,
Ber7
2位用户喜欢此帖子
I see, wonderful
Cheers to all!
This is my 5 cents to this thread. I only took some pieces of code from here and there, a little bit of make up, and.. voilá: my version of analog clock that works on "real" time
Updated 19jul2019 (Special thanks to [USERLINK]Razonar[/USERLINK]):
Annoying "purple line" eliminated. Path for sound files fixed. More realistic movement of hands clock.
MyClock2.sm (38.86 KiB)已下载 1395 次。
click_low.wav (171.1 KiB)已下载 367 次。
alarm.wav (891.03 KiB)已下载 376 次。
Hola Oscar. Very nice effects.
You can improve it multiply Play() by 1000 or something else but big. This avoid the horizontal purple line in the clock.
Also you define the location of the files as "D:\sound.wav". Using 1000*Play("sound.wav" ) searches sound in the same directory of the SMath file.
Finally notice that your blue hours hand jumps between hours, but not follow the actual movement of an hours hand clock. You need to take 1/2-1/6*el(NOW,1)-el(NOW,2)/600 as the arguments for sin, cos functions for place it between exact hours considering the minutes too.
2位用户喜欢此帖子
WroteHola Oscar. Very nice effects.
Thanks for your suggestions
I've updated the file and I uploaded the new one, you can check it here.
1页(9条)
