ComboBoxList Region
ComboBoxList Region - extends SMath Studio and SMath Viewer with ComboBoxes and ListBoxes - Messages
#21 Posted: 2016/3/10 14:34:59
1,441 likes in 2,932 posts.
PLUGIN UPDATED SMath Studio 0.97.5346 and later
- Fixed content update in SMath Viewer;
- Added context menu item to access settings' form;
Please note: if you use symbolic data as content and the content changes, this may mess up the form layout (as for now a feature to refresh the whole layout of the viewer is not available).
frapuano 2016/3/10 14:49:00
#22 Posted: 2016/6/8 11:23:31
Jason McCool
Jason McCool
9 likes in 78 posts.
Thank you very much for this plugin. I have been using it for several of my engineering worksheets for several months now and find it very useful. I notice it does not show up under the plugins tab of the Extensions Manager like it did when I first installed it. Is this still being developed? If so, is there a way to be able to change the width of the ComboListBox? The Combobox function has resizing grips, but doesn't include a dropdown list that I really need, like your plugin does. Is that something could be added, either through grips, or through an additional width parameter in the Settings dialog? Thank you again for all your hard work!
Jason
#23 Posted: 2016/6/8 13:12:30
You're very welcome Jason
I'm not sure on what you mean here, but if you mean that there aren't updates in the "Online gallery" is only because there weren't reports of bugs or new features added. But yes, the plugin is under development.
Maybe... the main problem is just about the minimum width, because I can't add ellipsis to truncate "properly" math objects; I'll see what I can do...
#24 Posted: 2020/6/24 08:08:53
PLUGIN UPDATED SMath Studio 0.99.7251 and later
  • Enhanced alignments of embedded MathRegions;
sergio 2020/6/24 13:48:00
#25 Posted: 2020/11/22 11:08:35
João Felipe Seráfico Melo
7 likes in 62 posts.
Hi! The description of a ComboBoxList region can't be moved around or resized. Same problem in the Numeric UpDown region.
#26 Posted: 2020/11/23 06:19:01
Hello [userlink]joaobr[/userlink],
confirmed. It is probably because these regions have fixed layout and the property is somehow inherited to the description tooltip, I have to check if this is intended.
#27 Posted: 2020/11/23 08:51:34
Thank you for your reply!
#28 Posted: 2021/2/6 20:03:38
Jason McCool
Jason McCool
Hello, Davide. I was curious if there was any way to set the ComboBoxList source programmatically rather than through the Settings dialog. What I'd like to do - if it's possible - is to be able to use an if statement to control the source and populate the dropdown options for this combobox based on which radio button was picked by a user earlier in the worksheet. I don't know if that's even possible now, but it might be a nice feature to add someday if it's not :d
Something like
If option 1 then
Combobox1.source = matrix x
Else
Combobox1.source = matrix y
There's probably some issues there with needing to define the source first for the box to be usable, but the properties not being defined prior to the combobox's location in the worksheet, or something along those lines. But I thought I'd mention it. Also, sometimes, the dropdown list is transparent and equations/text below the combobox show through it and make it hard to read. It doesn't do that all the time, though, so I'm not sure on a possible cause, but I thought it'd be worth mentioning as well.
Thanks!
Jason
#29 Posted: 2021/2/7 11:03:41
597 likes in 1,377 posts.
Thanks!
Jason
It is possible already, maybe not the way you mentioned but it gets the job done.
combolist.sm (4.47 KiB) downloaded 1546 time(s).
Davide Carpi 2021/2/7 20:48:00, Jason McCool 2021/2/8 13:13:00
#30 Posted: 2021/2/8 15:23:45
Jason McCool
Jason McCool
Very nice! That worked just fine. Thank you!
Jason
#31 Posted: 2022/6/20 11:37:54
Hi! I can't move the description of the Combo Box List region to the left. It is stucked above the region. Could this functionality be implemented? It would improve the look of many of my scripts. Thanks in advance!
#32 Posted: 2022/6/20 11:41:06
In addition, the width of this region could adjust to the content and/or fixed based on the longest input data. Just an idea!
#33 Posted: 2022/6/20 15:16:38
Hello, I'll check it, probably a wrong initialization by me.
I'll see what I can do, it is something that involves several things.
João Felipe Seráfico Melo 2022/6/20 15:28:00
#34 Posted: 2022/7/31 14:59:55
Prmtv
Prmtv
0 likes in 49 posts.
Hello. I found out an interesting feature. If i want "Show Description" at the object this plugin then if the text is too long, there are problems in SMathViewer. Text is either not included completely or is cut in half.
Maybe this is the problem called "joaobr" a few posts up.
#35 Posted: 2022/8/2 02:50:54
no, they are unrelated. I'll check this too.
#36 Posted: 2022/8/4 15:19:01
I've enabled multiline labels in Viewer, update and try again, it should work as expected now.
#37 Posted: 2023/6/29 20:25:53
giddyApples8
giddyApples8
0 likes in 15 posts.
I must be retarded because I can't figure out how to insert a combolist region.
#38 Posted: 2023/6/30 05:47:49
once you installed the plugin (from tools > plugins... > switch "Local storage" to "Online Gallery" > search combobox) you'll find the region in the Insert > Controls menu.
#39 Posted: 2023/6/30 12:34:14
giddyApples8
giddyApples8
Thanks. I didn't have that option, but a restart of the program fixed it.
