1页(7条)
From pic to SMath - 消息
This is how I'd handle it with the Maxima plugin. In the first case with ODE.2(), Solve() can be applied to use the initial conditions to determine the constants of integration k1 and k2. In the second case with desolve() the initial conditions are specified beforehand with atvalue(). You get the symbolic solution if you disable the value assignments to the system constants.
未找到文件。未找到文件。
未找到文件。未找到文件。
未找到文件。未找到文件。
未找到文件。未找到文件。
2位用户喜欢此帖子
Пример уже был на форуме: здесь.
1页(7条)
