LaTeX and/or Word converter to SMath Studio Format
LaTeX and/or Word converter to SMath Studio Format - 消息
#1 已发布: 2021/5/30 15:54:21
AlfredJ
AlfredJ
0个赞,共1个帖子。
Anyone know of a way to convert different math languages to SMath? :d
Preferably LaTeX to Smath Studio.
I have looked for a post about it; i found nothing concrete.
#2 已发布: 2021/5/30 22:20:26
983个赞,共6,866个帖子。
Latex, Word are not math language, just gyzma decoration.
If either one is typed as Smath expression, then code in work sheet.
#3 已发布: 2021/5/30 22:34:08
600个赞,共1,381个帖子。
There is a primitive plugin for saving worksheets as LaTeX.
But none for importing, and don't expect too much from tex exporting.
#4 已发布: 2021/5/31 12:30:17
1,443个赞,共2,936个帖子。
Import is always a challenge because you have to manage somehow things not supported on this side (i.e. you can look for the xmcd issues) and it becomes harder the more flexible is the syntax on the imported code.
BTW Data Exchange allows to export in XeLaTeX and should be updated to latest changes (it might miss something, though).
#5 已发布: 2021/5/31 14:27:59
127个赞,共342个帖子。
Davide,
It seems that it no longer works with your "Data Exchange" plugin. Andrey's "Tex FileType" plugin works yet (but I didn't try it intensively)
