Prolem with matrix and elements
Prolem with matrix and elements - can't assign an expression to an element of a matrix - 消息
#1 已发布: 2014/9/3 05:47:06
mingo81
mingo81
0个赞,共3个帖子。
Hi to everyone,
i have this kind of trouble.
i can't assign an expression to an element of a matrix.
first of all, i need to create a set of matrix with an index name which is controlled by the parameter ''n_matrix''
Than, for every of this matrix i need to assign an expression to every element of a matrix.
in this step, i can't manage to write the right command, because Smath don't recognize it.
is this an error of my program or Smath is not capable to do that?
i have attached the example.
thank you.
matrix of matrix.sm (7.23 KiB)已下载 1362 次。
#2 已发布: 2014/9/3 09:42:12
325个赞和1个踩,共2,052个帖子。
See this post, or search the Forum for "nested matrices"
Radaovan
