1页(13条)
SMath Studio on Linux - 消息
Try to run with sudo.
Whether appimage or regular, it won't run without sudo.
Well it will, but you must try a lot of times to make it run.
A link to a thread for further examination
This is a mono bug specific to debian distros except for one.
It is related with glibc and kernel version I suppose.
As far as I know due to my experience, only Debian based
distro I could run SMath without sudo is MXLinux (ahs).
If SMath doesn't run even, please run it under a terminal.
And post terminal output here, maybe it is a faulty plugin.
I created account on this forum only to write that if You install in Ubuntu 22.04:
libmono-cil-dev
libmono-db2-1.0-cil
mono-dbg
mono-devel
mono-tools-devel
then it should work without sudo. This is some bug within mono and installing mono debugging allows it to run apparently.
libmono-cil-dev
libmono-db2-1.0-cil
mono-dbg
mono-devel
mono-tools-devel
I am running SMath on my OrangePi-3b arm64 so far so good. Can anyone tell me how to use GTK themes for mono applications. SMath looks ugly
WroteI am running SMath on my OrangePi-3b arm64 so far so good. Can anyone tell me how to use GTK themes for mono applications. SMath looks ugly
Especially if your theme is dark for linux, SMath becomes unusable.
Buttons can't be seen, toolbars are too dark, etc.
So I edit smathstudio_desktop_mono file as below.
#!/bin/sh
HERE="$(dirname "$(readlink -f "${0}"
cd "${HERE}"
export MONO_WINFORMS_XIM_STYLE=disabled; GTK2_RC_FILES=/usr/share/themes/Raleigh/gtk-2.0/gtkrc exec mono "${HERE}//Solver.exe" "$@"
WINFORMS option also fixes ubuntu/debian crash.
Thanks Overlord, the thing is that developers should move from MONO to dotnet6/7/8 these are available in all Linux distributions! Recently a popular photo editor Pinta moved from MONO to dotnet8 ...similarly calcpad also did that & is very usable in Linux
Davide Carpi 2024/9/16 13:31:00
Wrotethese are available in all Linux distributions!
Actually, not every distribution has dotnet in their repository.
Some major ones like fedora or ubuntu have it, but rest doesn't.
overlord, I did that (customised run script) but Rayleigh theme was not loaded. I tested location / files ...content is there but theme is not loaded. Any suggestions?
If smath window is light themed, it should have ben loaded.
As far as I know, mono2 applications doesn't accept themes designs except colors.
In 2026; I still face x5 year old issue https://smath.info/en-US/forum/topic/CmDw2o/Some-little-anomalies-on-linux https://smath.info/en-US/forum/topic/WhzbAL/Bad-behaving-without-installed-fonts
Luckily this script / font resources will correct everything https://www.mediafire.com/file/apzsx0mi01qi55r/smath_linux_font_bug.7z/file
WroteIn 2026; I still face x5 year old issue https://smath.info/en-US/forum/topic/CmDw2o/Some-little-anomalies-on-linux https://smath.info/en-US/forum/topic/WhzbAL/Bad-behaving-without-installed-fonts
That's nice to see actual solutions. Would be better for inspection and long term accesss to upload your package in a repository (our SVN or a public GIT repo).
已编辑 2026/10/7 11:53:18
Previous Font bug and detailed solution hosted on GitHub: https://github.com/defencedog/smath-devel/tree/main/font-pack
Print preview bug and CUPS virtual printer producing blank pages solved at: https://github.com/defencedog/smath-devel/tree/main/print-patch
Another bug on Linux Mono is resolved by patching System.Windows.Forms.dll
Currently if I change File View (in file explorer) from default Tiles to Details (or something other) SMath closes. Problem is in Mono
Problem screenshoots and resolution is documented here https://github.com/defencedog/smath-devel/tree/main/winform-patch
1页(13条)
