MAXIMA PLUGIN expand
MAXIMA PLUGIN expand - 消息
#1 已发布: 2023/5/21 04:43:40
Angel695
Angel695
0个赞,共3个帖子。
Dose anyone know why using the function expand of maxima dosent work? Thanks
#2 已发布: 2023/5/21 05:39:28
1,362个赞,共2,276个帖子。
Any example of the problem? Use the paperclip button to attach screenshots.
#3 已发布: 2023/5/22 13:41:47
Angel695
Angel695
0个赞,共3个帖子。
Al usar el comando expand de maxima no ejecuta nada ejemplo
#4 已发布: 2023/5/22 16:15:35
1,362个赞,共2,276个帖子。
You have to use the functions correctly and you need to set optimization to None, otherwise SMath messes up the returned expression from Maxima.
Worksheet21.sm (3.74 KiB)已下载 1482 次。
#5 已发布: 2023/5/22 16:26:47
Angel695
Angel695
0个赞,共3个帖子。
GRACIAS
